LMAN updates ALL viewports, not just active one
purplepanda
Hi all,
I have been searching through threads and have yet to find a solution to my problem!
I have a drawing set up with my standard Layer States that I used for all projects.
In paper space, I have created 2 viewports which need to have different layer states.
I activate the first viewport and restore the layer state I want - things look good.
I create a second viewport and restore the layer state I want - BUT it updates both the active viewport AND the unactive viewport. Also, it doesn't completely update the unactive viewport - it just turns some layers on but doesn't actually reflect a particular layer state.
I can't figure out why this drawing is reacting differently than all my others! Is there some system variable or setting that needs to be changed?
SANTANA CONST 4.1 - INTERIORS 2017 1106.dwg
I am double checking to make sure I am current on all updates, but I think this is a drawing specific issue since I have another drawing that is NOT having this issue with LMAN and viewports.
