Raje
Select specified layer Objects and delete
Raje
Hii,
i have layer names like "Earth Line'", "Steel Line", "Concrete Line" etc..
so i need select all mentioned layer named containing objects and delete them.
any code for this task?
Thankyou..
Share this post
Link to post
LanloyLisp
Command: LAYMRG
:roll:
Give it a try..
Share this post
Link to post
Grrr
Not tested:
(defun C:test ( / acDoc SS )
 (cond
   ( (not (ssget "X" '((8 . "Earth Line',Steel Line,Concrete Line")))) (prompt "\nNo Selection.") )
   ( (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
     (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)
     (vlax-map-collection (setq SS (vla-get-ActiveSelectionSet acDoc)) ''((x) (vl-catch-all-apply 'vla-Delete (list x))))
     (vla-Delete SS)
(vl-load-com)(princ)
Share this post
Link to post
Raje
grrr thank you very much. it is working.
can you provide selecting objects only? instead of delete.
Thank you.
Share this post
Link to post
Grrr
Thank you.
Thanks for confirming,
This should limit the selection to the active viewport (as my previous suggestion selects objects in all viewports - and that might be unwanted) :
(defun C:test nil
 (sssetfirst nil
   (ssget "X"
     (list
       '(8 . "Earth Line',Steel Line,Concrete Line")
       (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))
Share this post
Link to post
LanloyLisp
:roll:
Give it a try..
My bad.. I thought you want to delete the layer itself..:geek:
Share this post
Link to post
Raje
Grrr thank you, it is also worked fine.
Share this post
Link to post
Raje
LOL its ok and thank you..
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
