TunzaGibbo
Attach arrow to a line
TunzaGibbo
I want to draw a line and add an arrow head to the end of the line. I can do this easily but when I pick the grip point on the opposite end to the arrow and move this point in any direction the arrow doesn’t rotate with the line. Is there a way that I can add some code to my lisp routine to make the arrow part of the line?
Share this post
Link to post
Aftertouch
Why dont you just use a LEADER
Share this post
Link to post
CyberAngel
Welcome to the CADTutor forum.
As Aftertouch indicates, a leader or multi-leader will give you a line with an arrow that stay aligned with each other. If you don't want text, you can select Options instead of typing text and use the None option.
Share this post
Link to post
SLW210
I use QLEADER when I just want a line with an arrow, but the OP mentions this is part of a LISP routine.
THIS may help.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
