HideQ
Is there a way to “pause” viewport display while running lisp.
HideQ
For example lisp is drawing complicated shapes out of individual lines – is there a way to “pause” the display for the duration of the function, so that complete linework just show all at once, instead of each individual line with flickering screen?
Many Thanks
Share this post
Link to post
ronjonp
You need to post the code you're using.
Share this post
Link to post
Lee Mac
Use entmake(x) or ActiveX methods rather than command calls.
Share this post
Link to post
HideQ
Thanks Lee Mac, I think that is the way to go.
I am new to the lisp world and was asking this question for few applications, but currently I am struggling with LISP allowing me to quickly work with point cloud in AutoCad 2016.
I am usually working with 3 viewports while modelling, e.g. slicing the cloud from side view and investigating from the top. I was hoping to move the crop of the point cloud up and down, similarly to cloudworx, so I came up with this crude solution:
(defun c:crop (/ cor1 cor2); point cloud rectangular crop
 (setq cor1 (getpoint "\nselect first corner:"))
 (setq cor2 (getcorner cor1 "\nselect second corner:"))
 (setq 2dcor1 (list (car cor1) (cadr cor1)))
 (setq 2dcor2 (list (car cor2) (cadr cor2)))
 (setq cloud (ssget "x" '((8 . "Cloud"))))	; point cloud have to be on the "Cloud" layer
 (command "POINTCLOUDCROP" cloud 2dcor1 2dcor2 "inside")
 (setq csd (- (cadr 2dcor2) (cadr 2dcor1)))
(defun c:fs () ;forward step
 (command "POINTCLOUDCROP" cloud "r")
 (setq 2dcor1 (list (car 2dcor1) (+ (cadr 2dcor1) csd)))
 (setq 2dcor2 (list (car 2dcor2) (+ (cadr 2dcor2) csd)))
(defun c:bs () ;backward step
 (setq 2dcor1 (list (car 2dcor1) (- (cadr 2dcor1) csd)))
 (setq 2dcor2 (list (car 2dcor2) (- (cadr 2dcor2) csd)))
(defun c:csd (/ a) ;change the slice step distance
 (setq a (getreal "\nnew cloud slice value:"))
 (setq csd a)
Among many issues with this lisp (work in progress) is the visible removing of the last crop, which can make it hard for examining the scan data. Any guidance on how to work around it or where to look for possible solution? ObjectARX seems to be the option, but it might be a slight overkill from my newbie perspective.
Edited by SLW210
Added Code Tags.
Share this post
Link to post
HideQ
Hello Dadgad,
Thank you for the link.I fell a little guilty, especially since I cannot edit this post :)
I will use those guidelines in the future.
Share this post
Link to post
SLW210
Fixed for you.
The # sometimes will not work in some browsers, to do it manually just [NOPARSE]
Your Code Here[/NOPARSE]
Your Code Here
Share this post
Link to post
