united Posted November 29, 2017 Share Posted November 29, 2017 Hi all I was just wondering if someone could shed some light on what is the best way to draw an arc between a set arc and a straight line. The straight line is adjustable in length, but orientation is set. Likewise ideally the existing arc is set in length and orientation. Therefore I would like to fit a new arc between the two. Thanking you In advance! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 30, 2017 Share Posted November 30, 2017 Post an image or a dwg to explain more if Fillet does not work, known problem with Autocad, use Circle TTR. Quote Link to comment Share on other sites More sharing options...
eldon Posted November 30, 2017 Share Posted November 30, 2017 Is the joining arc of known radius? A picture (or drawing) of what you are trying to do would be an immense help. Quote Link to comment Share on other sites More sharing options...
united Posted November 30, 2017 Author Share Posted November 30, 2017 I was trying to upload something fellas but it just wont work from imgur! arghh Quote Link to comment Share on other sites More sharing options...
united Posted November 30, 2017 Author Share Posted November 30, 2017 Quote Link to comment Share on other sites More sharing options...
united Posted November 30, 2017 Author Share Posted November 30, 2017 [/img] Quote Link to comment Share on other sites More sharing options...
eldon Posted November 30, 2017 Share Posted November 30, 2017 Well done for posting an image, but at that scale, both lines look to be straight. Perhaps a drawing containing only those two lines would be more useful, and can you show which points are fixed. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted November 30, 2017 Share Posted November 30, 2017 The entity on the left looks to be a polyline FWIW. OP - If you do not need a true arc, but need a smooth connection, take a look at the BLEND command. Quote Link to comment Share on other sites More sharing options...
