Quick question Connect arc and line
Hi all
I was just wondering if someone could shed some light on what is the best way to draw an arc between a set arc and a straight line. The straight line is adjustable in length, but orientation is set. Likewise ideally the existing arc is set in length and orientation.
Therefore I would like to fit a new arc between the two.
Thanking you In advance!
IZnZV
Well done for posting an image, but at that scale, both lines look to be straight.
Perhaps a drawing containing only those two lines would be more useful, and can you show which points are fixed.
