"Save as" or Opening file setting
ThrashMetal
<a href=SAVE_AS.png' alt='SAVE_AS.png'>
hello all, I kinda need help to bring back an old and standard setting when "saving as" or opening new files since the window that should appear when you select "save as" on the menu button does not appear instead i get to see the image above in which choices are limited. please help..thank you
