con
Change block by changing attribute ?
con
Is it possible to have attributes that change the block itself?
For instance: I have blocks of different heights and widths
example: a block with measurements 120x120
Attribute Height: 120
Attribute Width: 120
If I were to change it to
Attribute Width: 240
Could the block be replaced by a block with measurements 120x240?
Thanks in advance
Share this post
Link to post
steven-g
Nope, attributes can't drive blocks, but if you use dynamic blocks then altering either sizes or visibility states can change the values of the attributes.
Share this post
Link to post
BIGAL
Maybe a way around if the block is 1x1 in size then you can make the block 120x140 using X & Y scale. But you would have to update attribute vals but also think about using a dim with everything turned off but distance.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
