Designer
Lisp to show the visibility state of dynamic block on leader
Designer
Hi all,
It`s been a while.
Does anyone have a lisp to show on a leader the visibility state of a dynamic block?
Cheers
Share this post
Link to post
rlx
Just quickly cut-copy-pasted together :
; modified / supplemented lsp found on : [url]http://www.cadtutor.net/forum/showthread.php?39301-Block-into-multileader-text/page2&highlight=leader[/url]
(defun c:VisLabel (/ blk entl obj)
 (vl-load-com)
 (cond ((not (setq blk (car (entsel "\nSelect block: ")))))
       ((not (eq (cdr (assoc 0 (entget blk))) "INSERT")) (princ "\nInvalid object!"))
       ((setq pt (getpoint "\nSpecify first point: "))
        (setq entl (entlast))
        (vl-cmdf "_.mleader" "_non" pt "\\")
        (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf ""))
        (if (and (not (equal entl (setq entl (entlast)))) (setq entl (vlax-ename->vla-object entl)))
           (if (not (setq visname (GetBVis (vlax-ename->vla-object blk))))
             (vla-put-textstring  entl "No visibility")   (vla-put-textstring  entl visname)
; just some ccp (cut copy paste) from my RlxBlk.lsp
; (GetBVis (vlax-ename->vla-object (car (entsel))))
; get current visibility name block object
(defun GetBVis ( %blk / blk dic bvp bvn)
 (if (and (vl-every
     '(lambda (p)(vlax-property-available-p %blk p)) '(isdynamicblock hasextensiondictionary effectivename))
   (setq blk (vla-item (vla-get-blocks (vla-get-document %blk)) (vla-get-effectivename %blk)))
   (setq dic (dictsearch (vlax-vla-object->ename (vla-getextensiondictionary blk)) "ACAD_ENHANCEDBLOCK"))
   (setq bvp (findaso "BLOCKVISIBILITYPARAMETER" (massoc 360 dic)))
   (setq bvn (cdr (assoc 301 bvp))))
   (vl-some '(lambda (p) (if (= (vla-get-PropertyName p) bvn) (vlax-get p 'Value)))
     (vlax-invoke %blk 'getDynamicBlockProperties))))
(defun massoc ($i $l / a l)(while (setq a (assoc $i $l))(setq l (cons (cdr a) l) $l (cdr (member a $l))) l))
(defun FindAso ($v %l) (vl-some (function (lambda(x) (if (= $v (cdr (assoc 0 (setq e (entget x))))) e nil))) %l))
gr.Rlx
Share this post
Link to post
Designer
Thank you it worked.
I tried to change the line where you put to write (vla-put-textstring entl "No visibility") to show when there is no visibility mode to show the block name, i tried (vla-put-textstring entl effectivename) but it didn't work.
Can you help me again?
 (vl-load-com)
 (if (and (vl-every
gr.Rlx
Share this post
Link to post
rlx
sure :
; modified lsp found on : [url]http://www.cadtutor.net/forum/showthread.php?39301-Block-into-multileader-text/page2&highlight=leader[/url]
(defun c:VisLabel (/ blk entl pt visname)
        (setq entl (entlast) blk (vlax-ename->vla-object blk))
   (if (setq visname (GetBVis blk))
       (vlax-get-property  blk
  (if (vlax-property-available-p blk 'EffectiveName) 'EffectiveName 'Name))))))
 (if (and (vl-every '(lambda (p)(vlax-property-available-p %blk p)) '(isdynamicblock hasextensiondictionary effectivename))
gr.Rlx
Share this post
Link to post
Designer
Thanks your the best :)
Share this post
Link to post
