Ibanezboy21
attribute in dynamic block moves when using ctrl+c
Ibanezboy21
Hi guys,
For some reason every time i use ctrl+c and ctrl+v on this dynamic block that ive created it moves the attribute to a random spot.
Using the autocad copy command (hotkey c) works fine, this block also works fine on other drawings so its just this drawing.
any idea what it is?
the attribute is 'locked' so it shouldn't move at all.
HINGED DOOR GF.dwg
Share this post
Link to post
iconeo
I didn't look at the block but a lot of blocks that have the basepoint object in them have this problem. Known bug that I don't think AutoDesk is gonna fix.
Share this post
Link to post
SLW210
It is working fine here on AutoCAD 2018.
Share this post
Link to post
Ibanezboy21
yeah the block works itself, but when i paste it into this certain drawing it stops working and just moves randomly
maybe it is a bug since i cant figure out what else to do..
Share this post
Link to post
SLW210
Can you post the drawing where this is happening?
Have you tried cleaning up the drawing? -Purge, Audit, WBlock, etc.?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
