I don't know how, or why, this variable changed. My PLINETYPE variable ALWAYS resets itself to 0 (zero) and I can't figure out how to change it back permanently. I don't want to have to type in PLINETYPE each time I open or start a drawing, but I can't figure out how to do it. I searched the site, I exhausted Google, but I can't find an answer.
What can I do (besides anything LISP related) to fix this?
The variable is saved in the dwg; If you save the dwg with plinetype=1 and it opens with it =0, then some 3rd party or startup app is probably changing it. If that's the case you'll need to narrow it down to what app is causing it to change. If it's just in new drawings, set your Plinetype variable in your template file(s) and/or add this to your acaddoc.lsp file
(setvar "plinetype" 1); or 2
uh oh... that's lisp
You'll have better luck getting answers if you name your threads descriptively. I've changed the thread title for you. :thumbsup:
I agree with lpseifert. Add that line of code to your acaddoc.lsp and it should solve the problem.
