Script to select and delete block not working
pixel8er
Hi everyone
This simple script to select and delete the COS_DWGS_STATUS dynamic block from a series of drawings is not working. Any ideas?
(command "erase" (SSGET "X" '((0 . "INSERT") (2 . "COS_DWGS_STATUS" ))) "")
Thanks
Paul
Edited by pixel8er
You will need to check for dynamic block
a block and dynamic has 2 names you can look at
dynamic block
EffectiveName (RO) = "bolt"
Name = "*U200"
std block
EffectiveName (RO) = "NORTHN"
Name = "NORTHN"
This has no error checking and will delete all.
(defun delblock ( / ss x)
(setq ss (SSGET "X" '((0 . "INSERT"))))
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(if (= (vla-get-EffectiveName obj) "COS_DWGS_STATUS")
(vla-delete obj)
(delblk)
Thanks BIGAL, Champion! That worked perfectly. Just needed to adjust the function definition.
(defun delbl[b][color="red"]oc[/color][/b]k ( / ss x)
(vla-delete obj)
(delblk)
Dont forget the last one or make a C:delblock
Me personally pick the block get its effective name then run the code no need for hard coded block name. Error check added to make sure it was a block.
(defun delblock ( / ss x effname)
 (if   (and
         (setq obj (vlax-ename->vla-object (car (entsel "\nPick block/s to delete "))))
         (= (vla-get-objectname obj) "AcDbBlockReference")
   (setq effname (vla-get-EffectiveName obj))
         (if (= (vla-get-EffectiveName obj) effname)
           (vla-delete obj)
 (alert "you did not pick a block")
(delblock)
Edited by BIGAL
