Suzid6050
Yesterday by AutoCAD crashed and since then I have been experiencing a number of issues with all of my existing dwg files and any new files I create.
The prob is that I am unable to select items (objects/text/lines) before I select the commands. For instance I am unable to select a line and then press delete. I am also unable to select a viewport to lock and unable to select text to edit. I am also unable to copy with basepoint, or copy things in to a new drawing file. However I can delete / move as long as I select the command prior to selecting the item.
Has anyone got any solution of how I can resolve this issue? I am experiencing this issue across all of my AutoCAD files, not just one and have an important drawings which was due to be issued to the Client by Monday which I am unable to edit.
Thank you in advance for your help.
Link to post
If a lot was changed you may want to reset the sysvars to all the defaults. I have all of my sysvars set up in an ACADDOC.lsp so they get set the way I prefer every time.
Link to post
