Line type scale
Hello. I have problem in object (line) properties. Can not set dashed line type scaling in model view. Not happend nothing when changing value. Short lines stay the same size. I change value in ltscale,psltscale...autocad 2007
Thanks for answer.
Sent from my Redmi 3 using Tapatalk
What are your settings for the following variables:
LTSCALE
MSLTSCALE
CELTSCALE
LTSCALE 1
MSLTSCALE unknown command
CELTSCALE 1
On model view have line shorten otherwise on paper view wider
Thanks
There are 2 .lin files that come with AutoCAD, acad.lin and acadiso.lin, for Imperial and Metric, respectively.
Post an example drawing and end all doubt.
