Diesel Field Expression
By changing the numbers at the end first Diesel code of I can pass a part of the layout name to a field for a sheet number.
$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),0),1)
By naming a layout tab "1" or "2" I can use the second Diesel code to select between two different addresses and pass one or the other to an address field.
$(if,$(eq,$(getvar,ctab),1),"building 1",$(if,$(eq,$(getvar,ctab),2),"building 2"))
Is it possible to combine the first Diesel code with the second Diesel code so that I can use the first part of ONE layout tab to select a sheet number field, and the end part of the SAME layout tab would act as a pointer to select an address?
For example if the layout tab text was "A-1 1"
then the sheet number would be "A-1"
and the address field would be "building 1".
