hosyn
Load again the latest lisp file loaded???
hosyn
Hey guys
Are there approach for load again the latest lisp file loaded from some lsp file??o:)
Share this post
Link to post
Emmanuel Delay
I have a .lsp file on my desktop that loads other useful lisp files.
(defun openuseful ( / )
 (load "...\\lisp\\cabling\\movetofrom.lsp")
 (load "...\\lisp\\alp\\alp3.lsp")
 (load "...\\lisp\\furn\\furn_v5.lsp")
(openuseful)
You can also make Autocad auto-load a list of files that you provide.
But lisp does not remember which function is on which file.
Like you cannot write a function
(defun detectCurrentLispFile (/) ... ) . That question would not make sense to lisp.
Share this post
Link to post
rkmcswain
Hey guys
What exactly do you mean?
Are you loading a lisp file, then while you're working, someone is updating the code and you want to load it as soon as the file is updated?
Share this post
Link to post
hosyn
Yup, this is exactly what I need. (after updating code)
Share this post
Link to post
rkmcswain
And you want it to do this automatically, with no human interaction?
I suppose you'll need a reactor, and a function that can read the file dates. (some examples here possibly)
1. Load the function, and read/store the file date on the file.
2. Have the reactor check the file every so often (30 sec?), and if the file date/time is newer, repeat step 1.
Share this post
Link to post
Steven P
I use this:
(defun c:appreload ()
;;Re-load named LISP files
(setq mylispfolder "c:\\Users\\.....\\......\\")
 (setq myfiles (vl-directory-files mylispfolder "*.lsp" nil)) ;;myfiles is list of files in mylispfolder location
 (setq mylistlength (length myfiles)) ;;count of number of lsp files
 (setq acount -1)
 (repeat mylistlength
   (setq acount (1+ acount))
   (setq FailedtoLoad (strcat (nth acount myfiles) " failed to load"))
   (load (strcat mylispfolder (nth acount myfiles)) FailedtoLoad) ;;Loads each LISP file
which will load all the LISP files within a location. I use it when I have updated a LIPS 'appreload' and its reloads (I have a folder with all my LISPS in it)
However it won't reload a LISP file as soon as its been updated you still need to type in the command. For al the time that takes and the time it would take to research and write a code to do this automatically is it worth the effort?
Share this post
Link to post
BIGAL
If your writing and testing just make a temporary defun takes about 30 seconds.
(defun c:aaa ()(load "mynewprogram"))
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
