Colinmcintyre 10 Posted July 13, 2018 Hello everyone, band new to the forum and a novice with Autocad. I am working in Autocad 2016, trying to prepare artwork to be laser cut in steel. My linework is fairly intricate, lots of small contours. I have produced a smooth lwpolyline but my cutter says that importing it to his cam software makes it all jagged and unusable. He says I need to trace the lwpolyline by hand with pure arcs and minimum vertices. I know there must be a straight forward way for the software to do this for me. I have tried the WEED lsp but it does not work with lwpolyline. I tried OVERKILL just in case but there are no redundancies, just too many points. I have been trying to go the POTRACE route, taking a bitmap image and trying to render simple curves with Selig's application but I cannot seem to get the commands to work (operator error I'm sure). I am looking for any guidance you can offer, in kind of a desperate spot. I have hundreds of objects that need to be processed so it is a very intensive option to hand trace it all. I keep reading about the Polyline Diet lsp but I cannot find a downloadable lsp file anywhere. HELP, please! Share this post Link to post Share on other sites
Colinmcintyre 10 Posted July 13, 2018 I installed the pdiet lsp and it helps quite a bit. I am attaching a file that shows the original lwpolyline along with two reduced versions after applying PLD with different parameters. Advice on getting smoother curves with longer spans between points? Colin McIntyre Improved Edit Test 2010.dxf Share this post Link to post Share on other sites
