wimal
Not respond to coordinates.
wimal
In my drawing lines cant draw with coordinates. But when I pick points it can draw. Block cant insert to given points typing coordinates. But if I pick a point it can insert. Same file working properly in others PCs. Please help.
Share this post
Link to post
rkmcswain
Do you mean that you can't type in coordinates such as 1042.85,65428.1606 ?
Are you entering them in the format of X,Y?
Are you entering coordinates outside the LIMITS?
Share this post
Link to post
wimal
Yex I am entering as X,Y and the point is inside the limits.
Share this post
Link to post
eldon
Have you checked your OSNAPCOORD system variable?
Share this post
Link to post
wimal
Finally I found the solution. Press F12 or off the dynamic input button.
Share this post
Link to post
SLW210
If you want to use Dynamic Input and still enter coordinates, set the appropriate Value for DYNMODE.
Share this post
Link to post
