Vertical Wood Grain Hatch Pattern
Damilola
Hi Everyone,
I'm currently sinking in opened links on finding a vertical wood grain hatch pattern.
I finally found a hatch pattern close to what i have, but now it needs to be rotated by abut 27degrees.
Could anyone please help with this.
Attached is a sample of the Pattern
legno4 - Kopie.pat.txt
That is a Revit model pattern that can also be used in AutoCAD.
If you are working in Revit, you can
1) rotate a model pattern in situ where it has ben used as a surface pattern
2) use the free HatchKit Add-In for Revit to rotate the fill definition or create another rotated fill within the project.
3) load a pre-rotated pattern from a .PAT file.
If you are working in AutoCAD you can
1) rotate a hatch pattern while specifying a hatched area using that pattern
2) use a pre-rotated pattern from a custom .PAT file.
Here is your posted pattern rotated 27 degrees, suitable for Revit ot AutoCAD:
; Written by HatchKit Team Edition Trial
; HatchKit Team Edition Trial ©1990-2018 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2018-08-02
;-Time : 15:06:12
;-HatchKit Team Trial Version : 3.1.11.2768
;-HatchKit Team Trial Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*WOOD-REVIT
;%TYPE=MODEL
53.5650716758,-0.090797,0.1782,1.34164136,0.44721392,1.118,-1.1180684
45.434964197,0.3564,0.1816,0.948683222744,-0.316228023757,0.63246,-2.52981797483
63.8699222443,-0.31779,0.6237,3.60000102367,-0.200000116499,0.5,-4.50000166028
