selection set based on layer and color of a given object
tsotzo
Hi,
I am trying something like this:
(setq ed (entget (car (entsel))))
(setq lyr (cdr (assoc 8 ed)))
(setq clr (cdr (assoc 62 ed)))
How can I get a selection set based on layer and color of a given object?
Something like:
(setq objs (ssget "X" '((cons 8 lyr) (cons 62 clr)) ) )
[i know this is not working I write it just to give the idea.]
and then change the objects' layer to "0" and color to 2.
Thank you in advance
tso
Thank you Grrr!
It was just what I needed!
(defun C:A2 ( / ed ss1 )
(setq ss1 (ssget "X" (list (cons 8 (cdr (assoc 8 ed))) (cons 62 (cdr (assoc 62 ed))) ) ) )
(Command "chprop" ss1 "" "LA" "0" "C" 2 "")
... and great lesson from Lee Mac (as always :) )
Cheers!
