Romero
set distance by lisp in a dynamic block
Romero
Hi.
Maybe someone here in this forum can help me.
I'm trying to set the distance for a dynamic block of a single parameter; which is linear and is called Distance1.
I do not know what I'm doing wrong, but I can not do it and change the desired distance.
He helped me with the functions of Lee Mac, but something is wrong. Any help very similar, I will be completely grateful.
(defun c: ddd (/ obj dd)
(if (y (setq obj (car (entsel "\ ndynamic block:")
(setq dd (getdist "\ Length:"))))
(= "AcDbBlockReference" (vla- get-objectname (setq obj (vlax-esame-> vla-object obj))))
(=: vlax-true (vla-get-isdynamicblock obj))
(LM: setdynpropvalue obj "Distance1" dd)
(defun LM: setdynpropvalue (blk prp val)
(setq prp (strcase prp))
(vl-some        '(lambda (x)
(if (= prp (strcase (vla-get-propertyname x)))
(vla- put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
(cond (val) (t))
(vlax-invoke blk 'getdynamicblockproperties)     ) )
(vl-load-com) (princ)
Share this post
Link to post
Tharwat
Hi,
Try this function.
(defun set:distance (blk dis)
             (and (eq "Distance1" (vla-get-propertyname x)) (vlax-put x 'Value dis))
          (vlax-invoke (vlax-ename->vla-object blk) 'getdynamicBlockproperties)
) (vl-load-com)
Usage of above function:
(set:distance <BlockEntityName> <DistanceValue>)
Share this post
Link to post
Roy_043
Wow, the OP raises cross posting to a whole new level.:(:(:(
Share this post
Link to post
