Scaling 101?
Oscar
I struggle understanding how to scale objects properly. I know how to use the command and all but I don't really see how my co-workers figure out the scale factor. I think they look at the scale on the drawing like a 1/4"= 1' and go by that when I bring in blocks or text. I guess I am looking for someone to point me in the direction of a helpful video or explain it to me like Im 5 haha.
Edited by Oscar
Using your example, you want to determine how many 1/4" are in one 1' or 12".  Invert the fraction and multilply, 4/1 X 12 = 48 scale factor.
For 1/8" = 1'-0", 8/1 X 12 = 96 scale factor.
There are plenty of websites that go over this, many have the math already worked out for you on a PDF file.
good luck
Not sure if this is applicable to your case, but annotative text and blocks can help you resolve scaling issues. Of course, annotative objects open up their own cans of worms. The nice thing is that you define the size once and assign scales to the object as necessary.
9 hours ago, rkmcswain said:
You should draw everything full scale in model space, regardless if you are designing a watch, or a 2 million sq. ft. factory.
Then you can "scale" the objects in your viewport when you create your layout. See this for more info.
Thanks rkmcswain! that video helped alot.
  • Thanks 1
