notredave Posted September 11, 2018 Share Posted September 11, 2018 Good afternoon all, Can someone look at this drawing, SHT1 and tell me why I can't change the text width on text? I want text to be at .9 but when I go into styles or properties to change it, it reverts back to 1. On the flip side, if I change it to 2, it works. I am mindblowned. If someone can help me, I would appreciate it very much. Thank you, Dave TEST.dwg Quote Link to comment Share on other sites More sharing options...
eldon Posted September 11, 2018 Share Posted September 11, 2018 27 minutes ago, notredave said: .... this drawing, SHT1 and tell me why I can't change the text width on text? I want text to be at .9 but when I go into styles or properties to change it, it reverts back to 1. On the flip side, if I change it to 2, it works..... TEST.dwg This is because the Length precision is set to 0, so no decimal parts are seen. The text width is probably changed, but you only see the rounded up integer. 1 Quote Link to comment Share on other sites More sharing options...
notredave Posted September 11, 2018 Author Share Posted September 11, 2018 eldon, Thank you for your response. How do you change length precision? Quote Link to comment Share on other sites More sharing options...
eldon Posted September 11, 2018 Share Posted September 11, 2018 If you are using AutoCAD, then type LUPREC at the command line and enter the number of decimal places to be shown. If you are not using AutoCAD, then I'm afraid that I don't know. Quote Link to comment Share on other sites More sharing options...
notredave Posted September 11, 2018 Author Share Posted September 11, 2018 eldon, You are the man! It is working now. Thanks so much! Quote Link to comment Share on other sites More sharing options...
