DavidGraham Posted September 25, 2018 Share Posted September 25, 2018 I have a drawing open and using a LISP routine to report on some of the entities. The view is 'SW isometric'. I want the report to be a new drawing to contain diagrams using the view 'Top 2D', or maybe I should just create a new viewport within the first drawing. I'm not sure which is the better/easier method or if I should just write a dxf file that can be opened later. Thank you for your advice. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 25, 2018 Share Posted September 25, 2018 2nd question save dwg not dxf much better. Make as many viewports as you need put each one in its own layout. Quote Link to comment Share on other sites More sharing options...
DavidGraham Posted September 27, 2018 Author Share Posted September 27, 2018 Thanks Quote Link to comment Share on other sites More sharing options...
