ryankevin15 Posted October 2, 2018 Share Posted October 2, 2018 (edited) . Edited December 31, 2018 by ryankevin15 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 3, 2018 Share Posted October 3, 2018 (edited) Your order is not quite right Zoom E mspace Zoom e layouts and lock viewports Close Y next dwg. I know in Objectdbx you can get a list of all open dwgs it may then be as simple as writing a script to do the steps making sure the last DWG is the one you start the script in. Not something I would do normally. ; something like (setq acDocs (vla-get-documents (vlax-get-acad-object))) (vla-activate (vla-item acdocs 1)) Edited October 3, 2018 by BIGAL Quote Link to comment Share on other sites More sharing options...
mostafa badran Posted October 3, 2018 Share Posted October 3, 2018 Maybe this help only for single file, you can use it for multi file by using AutoScript (defun lockallvport (/ lay ent) (vlax-for lay (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)) ) (if (eq :vlax-false (vla-get-modeltype lay)) (vlax-for ent (vla-get-block lay) (if (= (vla-get-objectname ent) "AcDbViewport") (vla-put-displaylocked ent :vlax-true) ) ) ) ) (princ) ) (defun ZoomextentLayouts (/) ;; Zoom extents in All Layouts (excluding Model) ;; Alan J. Thompson, 12.23.10 (or *Acad* (setq *Acad* (vlax-get-acad-object))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument *Acad*))) ((lambda (ctab) (foreach layout (layoutlist) (setvar 'ctab layout) (vla-put-mspace *AcadDoc* :vlax-false) (vla-zoomextents *Acad*) ) (setvar 'ctab ctab) ) (getvar 'ctab) ) (princ) ) (defun c:cdwg (/) (vl-load-com) (ZoomextentLayouts) (lockallvport) (command "qsave" "close") (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 4, 2018 Share Posted October 4, 2018 A script is one way to do it like mostafa run a lisp that has the two steps the 1st is run the acdocs to find out how many DWG's are open use a repeat to write the script, I could be wrong but the script needs to run the two lines in each dwg to redo the acdocs variable item 0 is the 1st dwg so if 1 only will still work. (setq acDocs (vla-get-documents (vlax-get-acad-object))) (setq numDocs (vla-get-count acdocs)) open a script file here fo (Repeat numdocs (write-line "(setq acDocs (vla-get-documents (vlax-get-acad-object)))" fo) (write-line "(vla-activate (vla-item acdocs 0))" fo) (write-line "(load "locklaysetc")" fo) (write-line "close y" fo) ) (close fo) (command "script" yourscriptname) Quote Link to comment Share on other sites More sharing options...
rlx Posted October 4, 2018 Share Posted October 4, 2018 relatively quickly written (lite version from my RlxBatch application) , appie to run a script over all open drawings. Hope its self explanatory enough and bug free cause haven't got the time right now to do much testing (nor do I need the lite version when I have his big brother of course) (vl-load-com) (defun c:RlxScriptOpenDrawings ( / app docs open-docs dcl-fn dcl-fp dcl-id save-dwg reopen-dwg mister-slave slave-fp master master-fp run-scr) (setq app (vlax-get-acad-object) docs (vla-get-documents app)) (vlax-for doc docs ; no nameless drawings (if (= 1 (vlax-variant-value (vla-getvariable doc "DWGTITLED"))) (setq open-docs (cons (cons (vla-get-fullname doc) doc) open-docs)))) (RlxScriptOpenDrawings_Dialog_Start) (RlxScriptOpenDrawings_Exit) (if run-scr (command "_.script" master)) ) (defun RlxScriptOpenDrawings_Exit () (if (and dcl-fn (findfile dcl-fn))(vl-file-delete (findfile dcl-fn)))) (defun _CloseAllButCurrent (/ dwg ) (vlax-for dwg (vla-get-Documents (vlax-get-acad-object)) (if (= (vla-get-Active dwg) :vlax-False) (if (= (vla-get-ReadOnly dwg) :vlax-true) (vla-close dwg :vlax-False) (vl-catch-all-apply (function (lambda () (if (/= (getvar "dwgtitled") 0) (vla-save dwg))(vla-close dwg :vlax-False)))) ) ) ) ) (defun _quit_all ( / dwg) (vlax-for dwg (vla-get-Documents (vlax-get-acad-object)) (if (= (vla-get-active dwg) :vlax-false)(vla-close dwg :vlax-false))) (command-s "._close" "_y") ) (defun _close_all ( / dwg ) (vlax-for dwg (vla-get-Documents (vlax-get-acad-object))(vla-close dwg :vlax-True))) ; start with empty drawing and close the rest (defun MDI_Scr_Init () (eval "(setvar \"filedia\" 0)\n.new\n\n(load\"RlxScriptOpenDrawings\")\n(_CloseAllButCurrent)")) ; I say yeah yeah (defun MDI_Scr_Open ($fn) (strcat ".open\n" $fn "\n(while (= 1 (logand (getvar \"cmdactive\") 1))(command \"Yes\"))")) ; To save or not to save (defun MDI_Scr_Close () (if (eq save-dwg "1") (eval "(if (= (getvar \"writestat\") 1)(command \".qsave\" \".close\"))") (eval "(if (> (getvar \"dbmod\") 0) (command \".close\" \"no\")(command \".close\"))") ) ) (defun RlxScriptOpenDrawings_Write_MDI_Script ( / master-fp slave-commands) (cond ; debugging services : ; with proven reliabilty this can of course be one big giant 'and-function ((not (vl-consp open-docs)) (alert "No (named) open drawings")) ((or (null mister-slave) (and (= (type mister-slave) 'STR)(eq mister-slave ""))) (alert "Invalid script file name")) ((not (findfile mister-slave)) (alert (strcat "Unable to find script file : \n" mister-slave))) ((not (setq slave-fp (open mister-slave "r"))) (alert "Unable to read from slave script file")) ((not (vl-consp (setq slave-commands (_GetSlaveCommands slave-fp)))) (alert "No commands where found in slave script file")) ((not (setq master (vl-filename-mktemp "rlxscript" (getvar 'MYDOCUMENTSPREFIX) ".scr"))) (alert "Unable to create master script file")) ((not (setq master-fp (open master "w"))) (alert "Unable to write to master script file")) (t (write-line (MDI_Scr_Init) master-fp) (mapcar '(lambda (x) ; load the patient (write-line (MDI_Scr_Open x) master-fp) ; write all commands from slave script (mapcar '(lambda (cmd) (write-line cmd master-fp)) slave-commands) ; dump the patient (write-line (MDI_Scr_Close) master-fp) ) (mapcar 'car open-docs) ) ; if drawings must be reopened (if (eq reopen-dwg "1") (mapcar '(lambda (x)(write-line (strcat ".open " x) master-fp)) (mapcar 'car open-docs))) ) ) (if master-fp (progn (close master-fp)(gc)(setq RlxBatch-RunScriptOnExit t))) ) (defun _GetSlaveCommands ( fp / i l) (if fp (while (setq i (read-line fp))(setq l (cons i l))))(if fp (close fp))(if l (reverse l) nil)) (defun RlxScriptOpenDrawings_Dialog_Create () (if (and (setq dcl-fn (vl-filename-mktemp ".dcl")) (setq dcl-fp (open dcl-fn "w"))) (mapcar '(lambda (x)(write-line x dcl-fp)) '("ScriptOpenDrawings :dialog {label=\"Script Open Drawings (RLX 10/'18)\";" ":boxed_row {label=\"Script name\";" ":column {:edit_box {key=\"eb_script_name\";}" ":row {:button {label=\"Open\";key=\"bt_open_script_file\";fixed_width=true;}" ":button {label=\"Create\";key=\"bt_create_script_file\";fixed_width=true;}" ":button {label=\"Edit\";key=\"bt_edit_script_file\";fixed_width=true;}}}}" "spacer;:row {spacer;:toggle {label=\" Save \";key=\"tg_save_drawing\";}" ":toggle {label=\"Reopen\";key=\"tg_reopen_drawing\";}}spacer;ok_cancel;}"))) (if dcl-fp (close dcl-fp))(gc) ) (defun RlxScriptOpenDrawings_Dialog_Action () (mapcar '(lambda (x)(action_tile (car x) (last x))) '(("cancel" "(done_dialog 0)") ("accept" "(done_dialog 1)") ("eb_script_name" "(setq mister-slave $value)") ("bt_open_script_file" "(open_scriptfile)") ("bt_create_script_file" "(create_scriptfile)") ("bt_edit_script_file" "(edit_scriptfile)") ("tg_save_drawing" "(setq save-dwg $value)") ("tg_reopen_drawing" "(setq reopen-dwg $value)")) ) ) (defun RlxScriptOpenDrawings_Dialog_Start ( / drv vl tl dd rd ) (if (null dcl-fn)(RlxScriptOpenDrawings_Dialog_Create)) (if (and (setq dcl-id (load_dialog dcl-fn)) (new_dialog "ScriptOpenDrawings" dcl-id)) (progn (RlxScriptOpenDrawings_Dialog_Action) (setq drv (start_dialog)) (unload_dialog dcl-id) (cond ((= drv 0)) ((= drv 1)(go_script_yourself)) ) ) ) ) (defun go_script_yourself () (RlxScriptOpenDrawings_Write_MDI_Script) (setq run-scr t) ) (defun open_scriptfile ( / fn) (if (setq fn (getfiled "Open script file" "" "scr" 0)) (set_tile "eb_script_name" (setq mister-slave fn))) ) (defun create_scriptfile ( / fn fp) (if (and (setq fn (getfiled "Create script file" "" "scr" 1)) (setq fp (open fn "w"))) (progn (close fp)(gc)(set_tile "eb_script_name" (setq mister-slave fn)))) ) (defun edit_scriptfile () (if (and mister-slave (= (type mister-slave) 'STR) (findfile mister-slave)) (progn (startapp "notepad" mister-slave)))) Quote Link to comment Share on other sites More sharing options...
ryankevin15 Posted October 4, 2018 Author Share Posted October 4, 2018 6 hours ago, rlx said: relatively quickly written (lite version from my RlxBatch application) , appie to run a script over all open drawings. Hope its self explanatory enough and bug free cause haven't got the time right now to do much testing (nor do I need the lite version when I have his big brother of course) (vl-load-com) (defun c:RlxScriptOpenDrawings ( / app docs open-docs dcl-fn dcl-fp dcl-id save-dwg reopen-dwg mister-slave slave-fp master master-fp run-scr) (setq app (vlax-get-acad-object) docs (vla-get-documents app)) (vlax-for doc docs ; no nameless drawings (if (= 1 (vlax-variant-value (vla-getvariable doc "DWGTITLED"))) (setq open-docs (cons (cons (vla-get-fullname doc) doc) open-docs)))) (RlxScriptOpenDrawings_Dialog_Start) (RlxScriptOpenDrawings_Exit) (if run-scr (command "_.script" master)) ) (defun RlxScriptOpenDrawings_Exit () (if (and dcl-fn (findfile dcl-fn))(vl-file-delete (findfile dcl-fn)))) (defun _CloseAllButCurrent (/ dwg ) (vlax-for dwg (vla-get-Documents (vlax-get-acad-object)) (if (= (vla-get-Active dwg) :vlax-False) (if (= (vla-get-ReadOnly dwg) :vlax-true) (vla-close dwg :vlax-False) (vl-catch-all-apply (function (lambda () (if (/= (getvar "dwgtitled") 0) (vla-save dwg))(vla-close dwg :vlax-False)))) ) ) ) ) (defun _quit_all ( / dwg) (vlax-for dwg (vla-get-Documents (vlax-get-acad-object)) (if (= (vla-get-active dwg) :vlax-false)(vla-close dwg :vlax-false))) (command-s "._close" "_y") ) (defun _close_all ( / dwg ) (vlax-for dwg (vla-get-Documents (vlax-get-acad-object))(vla-close dwg :vlax-True))) ; start with empty drawing and close the rest (defun MDI_Scr_Init () (eval "(setvar \"filedia\" 0)\n.new\n\n(load\"RlxScriptOpenDrawings\")\n(_CloseAllButCurrent)")) ; I say yeah yeah (defun MDI_Scr_Open ($fn) (strcat ".open\n" $fn "\n(while (= 1 (logand (getvar \"cmdactive\") 1))(command \"Yes\"))")) ; To save or not to save (defun MDI_Scr_Close () (if (eq save-dwg "1") (eval "(if (= (getvar \"writestat\") 1)(command \".qsave\" \".close\"))") (eval "(if (> (getvar \"dbmod\") 0) (command \".close\" \"no\")(command \".close\"))") ) ) (defun RlxScriptOpenDrawings_Write_MDI_Script ( / master-fp slave-commands) (cond ; debugging services : ; with proven reliabilty this can of course be one big giant 'and-function ((not (vl-consp open-docs)) (alert "No (named) open drawings")) ((or (null mister-slave) (and (= (type mister-slave) 'STR)(eq mister-slave ""))) (alert "Invalid script file name")) ((not (findfile mister-slave)) (alert (strcat "Unable to find script file : \n" mister-slave))) ((not (setq slave-fp (open mister-slave "r"))) (alert "Unable to read from slave script file")) ((not (vl-consp (setq slave-commands (_GetSlaveCommands slave-fp)))) (alert "No commands where found in slave script file")) ((not (setq master (vl-filename-mktemp "rlxscript" (getvar 'MYDOCUMENTSPREFIX) ".scr"))) (alert "Unable to create master script file")) ((not (setq master-fp (open master "w"))) (alert "Unable to write to master script file")) (t (write-line (MDI_Scr_Init) master-fp) (mapcar '(lambda (x) ; load the patient (write-line (MDI_Scr_Open x) master-fp) ; write all commands from slave script (mapcar '(lambda (cmd) (write-line cmd master-fp)) slave-commands) ; dump the patient (write-line (MDI_Scr_Close) master-fp) ) (mapcar 'car open-docs) ) ; if drawings must be reopened (if (eq reopen-dwg "1") (mapcar '(lambda (x)(write-line (strcat ".open " x) master-fp)) (mapcar 'car open-docs))) ) ) (if master-fp (progn (close master-fp)(gc)(setq RlxBatch-RunScriptOnExit t))) ) (defun _GetSlaveCommands ( fp / i l) (if fp (while (setq i (read-line fp))(setq l (cons i l))))(if fp (close fp))(if l (reverse l) nil)) (defun RlxScriptOpenDrawings_Dialog_Create () (if (and (setq dcl-fn (vl-filename-mktemp ".dcl")) (setq dcl-fp (open dcl-fn "w"))) (mapcar '(lambda (x)(write-line x dcl-fp)) '("ScriptOpenDrawings :dialog {label=\"Script Open Drawings (RLX 10/'18)\";" ":boxed_row {label=\"Script name\";" ":column {:edit_box {key=\"eb_script_name\";}" ":row {:button {label=\"Open\";key=\"bt_open_script_file\";fixed_width=true;}" ":button {label=\"Create\";key=\"bt_create_script_file\";fixed_width=true;}" ":button {label=\"Edit\";key=\"bt_edit_script_file\";fixed_width=true;}}}}" "spacer;:row {spacer;:toggle {label=\" Save \";key=\"tg_save_drawing\";}" ":toggle {label=\"Reopen\";key=\"tg_reopen_drawing\";}}spacer;ok_cancel;}"))) (if dcl-fp (close dcl-fp))(gc) ) (defun RlxScriptOpenDrawings_Dialog_Action () (mapcar '(lambda (x)(action_tile (car x) (last x))) '(("cancel" "(done_dialog 0)") ("accept" "(done_dialog 1)") ("eb_script_name" "(setq mister-slave $value)") ("bt_open_script_file" "(open_scriptfile)") ("bt_create_script_file" "(create_scriptfile)") ("bt_edit_script_file" "(edit_scriptfile)") ("tg_save_drawing" "(setq save-dwg $value)") ("tg_reopen_drawing" "(setq reopen-dwg $value)")) ) ) (defun RlxScriptOpenDrawings_Dialog_Start ( / drv vl tl dd rd ) (if (null dcl-fn)(RlxScriptOpenDrawings_Dialog_Create)) (if (and (setq dcl-id (load_dialog dcl-fn)) (new_dialog "ScriptOpenDrawings" dcl-id)) (progn (RlxScriptOpenDrawings_Dialog_Action) (setq drv (start_dialog)) (unload_dialog dcl-id) (cond ((= drv 0)) ((= drv 1)(go_script_yourself)) ) ) ) ) (defun go_script_yourself () (RlxScriptOpenDrawings_Write_MDI_Script) (setq run-scr t) ) (defun open_scriptfile ( / fn) (if (setq fn (getfiled "Open script file" "" "scr" 0)) (set_tile "eb_script_name" (setq mister-slave fn))) ) (defun create_scriptfile ( / fn fp) (if (and (setq fn (getfiled "Create script file" "" "scr" 1)) (setq fp (open fn "w"))) (progn (close fp)(gc)(set_tile "eb_script_name" (setq mister-slave fn)))) ) (defun edit_scriptfile () (if (and mister-slave (= (type mister-slave) 'STR) (findfile mister-slave)) (progn (startapp "notepad" mister-slave)))) Some dialog box pops up when I run it. I just want it to save, zoom extents and close all open drawing files. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 5, 2018 Share Posted October 5, 2018 Maybe we are reading to much into this, a lisp called closemydwg is what is needed just autoload it, as it closes a dwg it will go to the next one, just type it again. The shorter typing use zzz as command name. Not that hard. Quote Link to comment Share on other sites More sharing options...
rlx Posted October 5, 2018 Share Posted October 5, 2018 (edited) oh very well then ; zoom - lock - close (defun c:zlc ( / d o s f c) (setq d (vla-get-documents (vlax-get-acad-object)) s (strcat (getvar 'MYDOCUMENTSPREFIX) "\\zlc.scr") f (open s "w") c "\n(while (= 1 (logand (getvar \"cmdactive\") 1))(command \"Yes\"))\n(load\"zlc\")\nzlv\n._qsave\n._close") (vlax-for x d (if (= 1 (vlax-variant-value (vla-getvariable x "DWGTITLED")))(setq o (cons (vla-get-fullname x) o)))) (princ "(setvar \"filedia\" 0)\n._new\n\n(load\"zlc\")\ncabc" f)(mapcar '(lambda (x)(princ (strcat "\n._open\n" x c) f)) o) (princ "\n" f)(princ "._close" f) (close f) (gc) (command "_.script" s)) ; zoom - lock viewports (defun c:zlv ( / a d l e) (vlax-for l (vla-get-layouts (setq d (vla-get-activedocument (setq a (vlax-get-acad-object))))) (vla-put-activelayout d l)(if (eq acpaperspace (vla-get-activespace d))(vla-put-mspace d :vlax-false))(vla-ZoomExtents a) (vlax-for e (vla-get-block l)(if (= (vla-get-objectname e) "AcDbViewport")(vla-put-displaylocked e :vlax-true))))) ; close all but current (defun c:cabc ( / d ) (vlax-for d (vla-get-Documents (vlax-get-acad-object)) (if (= (vla-get-Active d) :vlax-False) (if (= (vla-get-ReadOnly d) :vlax-true) (vla-close d :vlax-False) (vl-catch-all-apply (function (lambda ()(if (/= (getvar "dwgtitled") 0)(vla-save d))(vla-close d :vlax-False)))))))) (vl-load-com) (princ "\nZoom-Lock-Close (RLX 10/2018) : type ZLC to start\n") (princ) Edited October 5, 2018 by rlx added a few extra checks Quote Link to comment Share on other sites More sharing options...
