abra-CAD-abra Posted October 7, 2018 Share Posted October 7, 2018 Lee, MacAttV3-1 I may have uncovered a small bug in the above program. Using the MacAttExt command and selecting ‘Drawing List Mode’, when you export a specified directory, the resultant Excel file will return the CAD Filename equal to the number of blocks added, for example: If I add a directory containing 3 drawings, with each drawing containing 3 different blocks, it will return 3 lines of attribute data. However, the ‘CAD Filename’ column will contain 9 lines of data, as below: Tag1 Tag2 CAD Filename DWG-001003 EXAMPLE 3 C:\Users\admin\Desktop\test\DWG-001003.dwg DWG-001002 EXAMPLE 2 C:\Users\admin\Desktop\test\DWG-001003.dwg DWG-001001 EXAMPLE 1 C:\Users\admin\Desktop\test\DWG-001003.dwg C:\Users\admin\Desktop\test\DWG-001002.dwg C:\Users\admin\Desktop\test\DWG-001002.dwg C:\Users\admin\Desktop\test\DWG-001002.dwg C:\Users\admin\Desktop\test\DWG-001001.dwg C:\Users\admin\Desktop\test\DWG-001001.dwg C:\Users\admin\Desktop\test\DWG-001001.dwg I hope this is useful feedback. Regards, Quote Link to comment Share on other sites More sharing options...
