gbarre Posted October 18, 2018 Share Posted October 18, 2018 Using AutoCAD 2016, when I pick a point inside an area to HATCH, the frames of images attached to the drawing create boundaries for the hatch, even when the images are not visible and the image frame variable is turned off. How can I avoid this? Thanks. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 19, 2018 Share Posted October 19, 2018 If the images are on a layer turned off should work then use draw order. Quote Link to comment Share on other sites More sharing options...
gbarre Posted October 19, 2018 Author Share Posted October 19, 2018 12 hours ago, BIGAL said: If the images are on a layer turned off should work then use draw order. You are right!!! Even with the image off, and the image frame off, the hatch command detects the frame of the image if it is in a layer that is on. So I just changed the image to other layer and turned it off, and IT WORKED!! Problem solved. Thanks. Quote Link to comment Share on other sites More sharing options...
