Kai Hern Posted October 25, 2018 Share Posted October 25, 2018 Hey guys, may i know is it possible to let the dimension of the main assembly changed after main assembly was pack and go into different folder when i changed the dimension in the ' pack and go ' folder? Quote Link to comment Share on other sites More sharing options...
stevsmith Posted October 31, 2018 Share Posted October 31, 2018 When you pack and go it breaks the reference links from the original model. So, if you were to modify the pack'n'go file, it should not alter the original file. During the pack and go process you should change the filename as to differentiate between the two variants. Quote Link to comment Share on other sites More sharing options...
