rog1n Posted November 5, 2018 Share Posted November 5, 2018 Hello, I need to copy a parts of a map many times like the Video Is possible to combine copy with extrim or other method to make a rectangle and copy just the objected inside this rectangle to other point? example.dwg Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted November 5, 2018 Share Posted November 5, 2018 (edited) I would suggest you to create block or xref, then use XCLIP command, pick boundary polyline and finally just COPY multiple option or set COPYMODE to 1 prior COPY command... Edited November 5, 2018 by marko_ribar Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted November 7, 2018 Share Posted November 7, 2018 On 11/5/2018 at 7:43 PM, rog1n said: Is possible to combine copy with extrim or other method to make a rectangle and copy just the objected inside this rectangle to other point? Try to see if THIS is Ok. Quote Link to comment Share on other sites More sharing options...
