Edit Dynamic Block, Within Another Block
Jim Clayton
So I'm having a hard time finding a solution to this.  I have a dynamic weld symbol block.  If you open block editor, the middle portion is comprised of a separate dynamic block.  I need to change the font on this but I have no idea how to access it.  Please see attached to see what I'm talking about.  I'm also attaching a lisp to load in the even that it is a little fuzzy.  If you open it and it's super fuzzy, just drag/drop the lisp and it should clear up.  Tks.
Dyn Weld Sym.dwg
showpstyle.LSP
