Get list of LineTypes in dwg
ziele_o2k
 Share
This solution work form me, but maybe I'm missing something?
(vlax-for #item (vla-get-LineTypes (vla-get-ActiveDocument (vlax-get-acad-object)))
    (if (and
            (not (wcmatch (strcase (vla-get-name #item)) "BYBLOCK,BYLAYER"))
            (= (logand (cdr (assoc 70 (entget (vlax-vla-object->ename #item)))) 16) 0)
        (setq line_types_in_drawing (cons (strcase (vla-get-name #item)) line_types_in_drawing))
You could iterate with vanilla, without having to reconvert every definition:
(while (setq d (tblnext "LTYPE" (not d)))
  (if (= 0 (logand (cdr (assoc 70 d)) 16))
    (setq L (cons (cdr (assoc 2 d)) L))
(= (length L) (length line_types_in_drawing)) >> T
Another?
    (if (and
            (snvalid (setq n (strcase (vla-get-name #item))))
            (not (wcmatch n "BYBLOCK,BYLAYER"))
        (setq L (cons n L))
39 minutes ago, Lee Mac said:
The snavalid test is redundant - if the linetype already exists, the name must be valid.
The snvalid function is used to check for xref-dependent linetypes.
(defun test ( / lst)
  (vlax-for obj (vla-get-linetypes (vla-get-activedocument (vlax-get-acad-object)))
    (if (not (wcmatch (strcase (vla-get-name obj)) "*|*,BYBLOCK,BYLAYER"))
      (setq lst (cons (vla-get-name obj) lst))
  (reverse lst)
Edited by Roy_043
 Share
