jonathann3891
Erase Layer/Object problem
jonathann3891
The code below is only supposed to delete the layers listed in the code but its also deleting layers that aren't listed. I even tested it on a drawing that didn't have the layers listed and it still deleted a bunch of layers, so I dont know what the issue is.
(defun c:demo  (/ aDoc name)
     (setvar 'Clayer "0")
     (repeat 4
           (vla-purgeall
                 (setq aDoc (vla-get-ActiveDocument
                                  (vlax-get-acad-object)))))
     (vlax-for
            itm
                 (vla-get-layers aDoc)
           (if (and
                     (not (wcmatch
                                (setq name (vla-get-name itm))
                     (not (eq name "0"))
                     (member name
                                  '("3dTxtBmXe"
                                    "3dTxtBmXp"
                                    "3dTxtBmXp-LOCKED"
				    "3dTxtBmYe"
				    "3dTxtBmYp"
				    "3dTxtBmYp-LOCKED"
				    "3dTxtBrH"
				    "3dTxtBrVx"
				    "3dTxtBrVy"
				    "3dTxtColx"
				    "3dTxtColy")))
                       (vla-put-lock itm :vlax-false)
                       (vl-cmdf "_.-laydel" "_N" name "" "_Y"))
     (repeat 4 (vla-purgeall aDoc))
Share this post
Link to post
Roy_043
Well you do call vla-purgeall...
Share this post
Link to post
jonathann3891
You are completely right! It been a good while sense I've messed with lisp.
Thank you, Roy! Its working as it should now.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
