ILoveMadoka Posted December 6, 2018 Share Posted December 6, 2018 I need to be able to <CTRL> V a text string from my clipboard in response to a Getstring prompt. (Setq X (Getstring T "\nEnter Name:")) Currently, if I <CTRL> C, it pastes the text and executes a carriage return. <unwanted> If i first pick in the Command line and then press <CTRL> C, it pastes the text but leaves me on the command line (Which is what I need) Is there a way to paste a text string (from the clipboard) i response to the prompt without the return?? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 6, 2018 Share Posted December 6, 2018 (edited) I'm not sure that I fully understand your requirements, or why you wouldn't read the clipboard content directly, but perhaps issuing (textscr) to switch focus to the command-line prior to issuing the getstring prompt may offer the solution you are after. Edited December 6, 2018 by Lee Mac 1 Quote Link to comment Share on other sites More sharing options...
Grrr Posted December 6, 2018 Share Posted December 6, 2018 Lee, I understand that OP wants to prompt for a string (as default) and also including the option to paste the content from clipboard. So I find this one suitable for the task. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted December 7, 2018 Author Share Posted December 7, 2018 I have a text string that I am selecting which has a backslash (every time). I use this text to create a view which will have the same text but I have to remove the \ since it is an invalid character. U replace the "\" with a space. This is crude and simple but it works. I am doing these steps hundreds of times and I am simply trying to streamline the process. I have to select the text string in advance. I highlight the text and press <CTRL> C before running this. (defun C:VC () (prompt "\nCreate View Window") (Setq VName (Getstring T "\nEnter View Name:")) ; I paste the preselected text here, on the command line [picking in the command line first] (Setq PT1 (getpoint "\nPick First Point of Window:")) (Setq PT2 (getpoint "\nPick Second Point of Window:")) (command "-View" "Window" VName PT1 PT2) (princ)) I had to change my DYNMODE to 0 due to the CopyClip issue... Now, it would be awesome to simply select the the text string (entsel), remove the "\" in lisp and have lisp generate the valid view name and use that in the view creation step. I will probably do that in time but this will work for my immediate and urgent need. There is almost always a %%u as a prefix in the text but the <CTRL> C ignores that. Hope that clears up what I'm trying to do... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 7, 2018 Share Posted December 7, 2018 (edited) Try the following: (defun c:vc ( / cmd ent pt1 pt2 str ) (while (not (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect text containing view name: "))) (cond ( (= 7 (getvar 'errno)) (prompt "\nMissed, try again.") ) ( (null ent)) ( (/= "TEXT" (cdr (assoc 0 (entget ent)))) (prompt "\nThe selected object is not single-line text.") ) ( (= "" (setq str (cleanstring (cdr (assoc 1 (entget ent)))))) (prompt "\nThe text content is not valid for use as a view name.") ) ( (and (setq pt1 (getpoint "\nSpecify first point of window: ")) (setq pt2 (getcorner pt1 "\nSpecify opposite point of window: ")) ) (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (vl-cmdf "_.-view" "_w" str "_non" pt1 "_non" pt2) (setvar 'cmdecho cmd) ) ) ) ) ) (princ) ) (defun cleanstring ( str ) (while (wcmatch str "*%%[OoUu]*") (foreach c '("O""o""U""u") (setq str (vl-string-subst "" (strcat "%%" c) str))) ) (vl-string-trim " " (vl-string-translate "\\<>/?\":;*|,=`" " " str)) ) (princ) Edited December 7, 2018 by Lee Mac Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted December 7, 2018 Author Share Posted December 7, 2018 Lee, That works perfectly! Once again you are Totally Awesome!! Thank you so very much Sir!! ps: I really do appreciate it! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 7, 2018 Share Posted December 7, 2018 You're welcome! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 8, 2018 Share Posted December 8, 2018 Perhaps another way and like Lee read the value out of the clipboard then I would use my getvals3.lsp DCL with a 1 line "Please enter string", the clipboard value would appear as a default value in the dcl or just type in a new string. Both options covered. I have posted getvals3.lsp many time you should be able to find it. Quote Link to comment Share on other sites More sharing options...
