CAD Nauseam Posted December 12, 2018 Share Posted December 12, 2018 What’s DOSLib? DOSLib is a free library of LISP functions that adds a lot of functionality to AutoLISP/Visual LISP/BricsCAD LISP. It makes a lot of programming tasks a lot easier, because instead of writing a bunch of code to do tricky stuff, you can just load the library and call a ready-made (dos_xxx) function. There are hundreds of functions that cover the following areas (taken from the McNeel Wiki): Drives – Check for drives, change between drives, and check available disk space. Paths – Manipulate path specifications. Folders – Create, rename, remove, select, and change folders. Return special operating system folders. Files – Copy, … The post DOSLib goes open source appeared first on cad nauseam. View the full article Quote Link to comment Share on other sites More sharing options...
