ILoveMadoka
I have a legacy drawing where someone has changed some of the leader arrows to dots
but they are using the wrong symbol and wrong size.
I can select the leader in question and change the properties of these two items
in the Properties dialog.
Can this be accomplished via lisp?
(Command "xxxx" "Dot")
; Or
(Setvar "xxxx" "Dot")
(Command "dimasz" .09375)
Properties says it is a Leader
I really would prefer to not make a whole new Style for these items
but there are so many that need to be changed scattered across the many sheets, that it would be a huge time saver with a small routine..
I don't see it here..
(setq XD (entget (car (entsel))))
* List in AutoLISP format *((-1 . <Entity name: 29f052416f0>)
(0 . LEADER) (330 . <Entity name: 29ed564db80>) (5 . C0C37) (100 . AcDbEntity) (67 . 1)
(410 . SH65H) (8 . Text) (100 . AcDbLeader) (3 . STANDARD) (71 . 1) (72 . 0) (73 . 3)
(74 . 1) (75 . 0) (40 . 0.0) (41 . 0.0) (76 . 3) (10 4.33416 8.92996 0.0)
(10 4.61755 10.2826 0.0) (10 4.73268 10.2826 0.0) (340 . <Entity name: 0>)
(211 1.0 0.0 0.0) (210 0.0 0.0 1.0) (212 0.0 0.0 0.0) (213 0.0 0.0 0.0))
Variable name is ENT
or here..
(entget (car (entsel)) '("ACAD"))
Select object: ((-1 . <Entity name: 29f052416f0>) (0 . "LEADER") (330 . <Entity name: 29ed564db80>)
(5 . "C0C37") (100 . "AcDbEntity") (67 . 1) (410 . "SH65H") (8 . "Text") (100 . "AcDbLeader") (3 . "STANDARD")
(71 . 1) (72 . 0) (73 . 3) (74 . 1) (75 . 0) (40 . 0.0) (41 . 0.0) (76 . 3) (10 4.33416 8.92996 0.0)
(10 4.61755 10.2826 0.0) (10 4.73268 10.2826 0.0) (340 . <Entity name: 0>) (211 1.0 0.0 0.0) (210 0.0 0.0 1.0)
(212 0.0 0.0 0.0) (213 0.0 0.0 0.0) (-3 ("ACAD" (1000 . "DSTYLE") (1002 . "{") (1070 . 41) (1040 . 0.09375)
(1070 . 40) (1040 . 1.0) (1070 . 49) (1040 . 0.1875) (1070 . 341) (1005 . "5AE25") (1070 . 345) (1005 . "12")
(1070 . 346) (1005 . "12") (1070 . 347) (1005 . "12") (1002 . "}"))))
Arrow size?
(1040 . 0.1875)
Do you use (entmod) to change??
I've looked here for some insight (It is not obvious to me..)
Autocad 2018 DXF Group Codes
This is beyond me
I'm lost... (I am trying though)
Help please?
Edited by ILoveMadoka
This is what I came up with for anyone else who may need it...
(It works for my situation)
(Defun c:AH1 ()
(Prompt "\nSelect Leader Objects to Change:")
(Setq SS (ssget))
(command "DIMOVERRIDE" "DIMLDRBLK" "Dot" "DIMASZ" "0.09375" "" ss "")
(Princ))
Alternatively you could use ActiveX .. it's a bit easier than sifting through DXF codes:
; IAcadLeader: AutoCAD Leader Interface
; Property values:
;   Annotation = #<VLA-OBJECT IAcadMText 000001bc3526b298>
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff730986558>
;   ArrowheadBlock = ""
;   ArrowheadSize = 0.18
;   ArrowheadType = 0
;   Coordinate = ...Indexed contents not shown...
;   Coordinates = (799357.0 826469.0 0.0 799347.0 826482.0 0.0 ... )
;   DimensionLineColor = 256
;   DimensionLineWeight = -1
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000001bc062bc078>
;   EntityTransparency = "ByLayer"
;   Handle (RO) = "643FD"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000001bc3f19c988>
;   Layer = "leader"
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   Normal (RO) = (0.0 0.0 1.0)
;   ObjectID (RO) = 2241
;   ObjectName (RO) = "AcDbLeader"
;   OwnerID (RO) = 2240
;   PlotStyleName = "ByLayer"
;   ScaleFactor = 20.0
;   StyleName = "Standard"
;   TextGap = 0.09
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000001bc3f19e000>
;   Type = 2
;   VerticalTextPosition = 0
;   Visible = -1
(setq o (vlax-ename->vla-object (car (entsel))))
(vla-put-arrowheadblock o "Dot")
(vla-put-arrowheadsize o 0.09375)
4 minutes ago, ILoveMadoka said:
These all work perfectly if it a LEADER that is selected.
None of them work if an MLEADER is selected. 😕
Pick your mleader and see what properties are available:
(defun c:vlaxprop (/ e)
  (if (setq e (car (entsel "\nSelect object to show data: ")))
    (vlax-dump-object (vlax-ename->vla-object e) t)
  (textscr)
; IAcadMLeader: AutoCAD Multi-Leader Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff761b1b0b8>
;   ArrowheadType = 0
;   BlockConnectionType = 0
;   BlockScale = 1.0
;   ContentBlockName = ""
;   ContentBlockType = 6
;   ContentType = 2
;   Document (RO) = #<VLA-OBJECT IAcadDocument 0000029ecd660d18>
;   DogLegged = -1
;   DoglegLength = 0.125
;   Handle (RO) = "C620E"
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000029f217d5918>
;   LandingGap = 0.09
;   Layer = "Text"
;   LeaderCount (RO) = 1
;   LeaderLineColor = #<VLA-OBJECT IAcadAcCmColor 0000029f217d62d0>
;   LeaderLinetype = "BYBLOCK"
;   LeaderLineWeight = -2
;   LeaderType = 1
;   Linetype = "BYLAYER"
;   Lineweight = -1
;   ObjectID (RO) = 73
;   ObjectName (RO) = "AcDbMLeader"
;   OwnerID (RO) = 74
;   ScaleFactor = 1.0
;   TextAttachmentDirection = 0
;   TextBackgroundFill = 0
;   TextBottomAttachmentType = 0
;   TextDirection = 5
;   TextFrameDisplay = 0
;   TextHeight = 0.125
;   TextJustify = 3
;   TextLeftAttachmentType = 1
;   TextLineSpacingDistance = 0.208333
;   TextLineSpacingFactor = 1.0
;   TextLineSpacingStyle = 1
;   TextRightAttachmentType = 5
;   TextRotation = 0.0
;   TextString = "\\A1;7/16\" X 45%%D \\PSNIPE"
;   TextStyleName = "ROMANS"
;   TextTopAttachmentType = 0
;   TextWidth = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 0000029f217d5bb0>
;   Visible = -1
; Methods supported:
;   AddLeader ()
;   AddLeaderLine (2)
;   AddLeaderLineEx (1)
;   ArrayPolar (3)
;   ArrayRectangular (6)
;   Copy ()
;   Delete ()
;   GetBlockAttributeValue (1)
;   GetBoundingBox (2)
;   GetDoglegDirection (1)
;   GetExtensionDictionary ()
;   GetLeaderIndex (1)
;   GetLeaderLineIndexes (1)
;   GetLeaderLineVertices (1)
;   GetVertexCount (1)
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   RemoveLeader (1)
;   RemoveLeaderLine (1)
;   Rotate (2)
;   Rotate3D (3)
;   ScaleEntity (2)
;   SetBlockAttributeValue (2)
;   SetDoglegDirection (2)
;   SetLeaderLineVertices (2)
;   SetXData (2)
;   TransformBy (1)
;   Update ()
T
