ehsantavassolian Posted December 24, 2018 Share Posted December 24, 2018 HI I searched for an autolisp function to give me four-corner coordinates of image. I found the link below. But this app has a problem https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/image-coordinates/td-p/1480589 I am in a problem, I am searching an alternative way to get Image Coordinates in Autocad. The Image may be clipped. Quote Link to comment Share on other sites More sharing options...
maratovich Posted December 24, 2018 Share Posted December 24, 2018 Why is this? Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted December 24, 2018 Share Posted December 24, 2018 I've added a reply to that link... Not sure, but try v.azarko's code with that sub function added (rotate_0_a pt ang)... HTH., M.R. Quote Link to comment Share on other sites More sharing options...
ehsantavassolian Posted December 24, 2018 Author Share Posted December 24, 2018 1 hour ago, maratovich said: Why is this? For the analysis of the data bank I have built, I need to introduce coordinates to add the image to the data bank Quote Link to comment Share on other sites More sharing options...
ehsantavassolian Posted December 25, 2018 Author Share Posted December 25, 2018 11 hours ago, marko_ribar said: I've added a reply to that link... Not sure, but try v.azarko's code with that sub function added (rotate_0_a pt ang)... HTH., M.R. The program worked well, thank you very much Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted December 25, 2018 Share Posted December 25, 2018 @ehsantavassolian I've just added my version for which I think is more concise and precise... Check that link again - I suggest that you finally use my version... M.R. Quote Link to comment Share on other sites More sharing options...
ehsantavassolian Posted December 25, 2018 Author Share Posted December 25, 2018 (edited) 2 hours ago, marko_ribar said: @ehsantavassolian I've just added my version for which I think is more concise and precise... Check that link again - I suggest that you finally use my version... M.R. You said the right. This is more concise and precise. I used your version thanks This is more concise Edited December 25, 2018 by ehsantavassolian Quote Link to comment Share on other sites More sharing options...
maratovich Posted December 25, 2018 Share Posted December 25, 2018 It seems to me that the same person is talking to himself with different nicknames ... Quote Link to comment Share on other sites More sharing options...
