cadsterdyne Posted December 29, 2018 Share Posted December 29, 2018 Dear Forum. I have over 1000's of rectangles which represent walls. i need to extract length and breadth of the rectangles while applying a unique naming code to each rectangle and want the results to be tabulated in excel format UNIQUE CODE LENGTH BREADTH RG1 1500 150 RG2 850 150 and so on..... Kindly advice... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 31, 2018 Share Posted December 31, 2018 When dealing with plines your rectangs, you can simply get the vertices then get the distance between pt1-pt2 and pt2 - pt3 ie length & breadth. Ignore short- long for moment. The simplest then is to export a csv. You can do direct to excel but adds a extra level of complexity. The other option is to label each rectang. Again in some sort of order an extra level of complexity. What is your skill with lisp ? This is the vertice part the points are in the list co-ordsxy By the way if your rectangs are lines no way to do much. pline co-ords2.lsp Quote Link to comment Share on other sites More sharing options...
ronjonp Posted December 31, 2018 Share Posted December 31, 2018 Post your sample drawing. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 31, 2018 Share Posted December 31, 2018 ronjonp did you solve this problem before ? Pretty sure its been done just takes some time to find. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted December 31, 2018 Share Posted December 31, 2018 12 minutes ago, BIGAL said: ronjonp did you solve this problem before ? Pretty sure its been done just takes some time to find. Probably .. but I hate guessing. It could be very simple or very complex based on how the drawing is put together. Too many times code is written to decipher a poorly drafted plan. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 31, 2018 Share Posted December 31, 2018 Agree this is a simple test pick only a few rectangs. plinelen-width.lsp Quote Link to comment Share on other sites More sharing options...
cadsterdyne Posted December 31, 2018 Author Share Posted December 31, 2018 5 hours ago, ronjonp said: Post your sample drawing HI ronjonp. PFA drawing file they are not actually wall but rectangles which i have drafted over the wall layout. i need to extract length and breadth of the rectangles while naming them uniquely and exported to excel. Thanking you. RECTANGLE LANDB.dwg Quote Link to comment Share on other sites More sharing options...
cadsterdyne Posted December 31, 2018 Author Share Posted December 31, 2018 6 hours ago, BIGAL said: What is your skill with lisp hi BIGAL. Thank you for the reply. My skill with LISP is at basic level not enough to stitching code as per your provided directions. i had started referring lessons and learning lisp from. JefferyPSanders.com http://ronleigh.com/autolisp/ Quote Link to comment Share on other sites More sharing options...
ronjonp Posted December 31, 2018 Share Posted December 31, 2018 (edited) (defun c:foo (/ a b c d e l n p pr s) (defun _wf (fn l / f) (cond ((and (eq 'str (type fn)) (setq f (open fn "w"))) (foreach x l (write-line x f)) (close f) fn ) ) ) (setq pr "RG") (cond ((and (setq s (ssget "_a" (list '(0 . "lwpolyline") '(90 . 4) (cons 410 (getvar 'ctab)))))) (setq l '("ID,LENGTH,WIDTH")) (setq n 0) (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (vla-getboundingbox (vlax-ename->vla-object x) 'a 'b) (setq c (mapcar 'vlax-safearray->list (list a b))) (setq d (vl-sort (mapcar 'abs (mapcar '- (car c) (cadr c))) '>)) (setq p (mapcar '+ (mapcar '/ (mapcar '+ (car c) (cadr c)) '(2. 2.)))) (entmakex (list '(0 . "TEXT") '(100 . "AcDbEntity") '(8 . "ID_Text") '(100 . "AcDbText") (cons 10 p) (cons 40 (cadr d)) (cons 1 (setq e (strcat pr (itoa (setq n (1+ n)))))) '(50 . 0.0) '(41 . 1.0) '(51 . 0.0) '(7 . "Standard") '(71 . 0) '(72 . 1) (cons 11 p) '(210 0.0 0.0 1.0) '(100 . "AcDbText") '(73 . 2) ) ) (setq l (cons (strcat e "," (vl-princ-to-string (car d)) "," (vl-princ-to-string (cadr d))) l) ) ) ;; Writes CSV text file to same directory as drawing (_wf (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv") (reverse l)) ) ) (princ) ) (vl-load-com) Edited January 7, 2019 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
cadsterdyne Posted January 1, 2019 Author Share Posted January 1, 2019 ronjonp. Gold Mr. You made Gold. Exactly what it should do....Blink of an eye...!!! Woo!! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted January 1, 2019 Share Posted January 1, 2019 Glad to help. Happy New year ! 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 6, 2019 Share Posted January 6, 2019 Hi Ronjonp Turn the walls at 45 deg,s and bounding box will not work hence the method of using co-ordinates. I thought about an angle wall as a first step. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted January 6, 2019 Share Posted January 6, 2019 Yup. Code based off of example drawing. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted January 7, 2019 Share Posted January 7, 2019 On 1/5/2019 at 7:41 PM, BIGAL said: Hi Ronjonp Turn the walls at 45 deg,s and bounding box will not work hence the method of using co-ordinates. I thought about an angle wall as a first step. Here's a version for rotated rectangles :). (defun c:foo (/ _r _wf a b d e l n pr s) (defun _wf (fn l / f) (cond ((and (eq 'str (type fn)) (setq f (open fn "w"))) (foreach x l (write-line x f)) (close f) fn ) ) ) (defun _r (l / r) (if (and (setq r (mapcar '(lambda (a b) (distance a b)) l (append (cdr l) (list (car l))))) (equal (car r) (caddr r) 1e-8) (equal (cadr r) (cadddr r) 1e-8) ) (append (vl-sort (list (car r) (cadr r)) '>) (list (mapcar '+ (mapcar '/ (mapcar '+ (car l) (caddr l)) '(2. 2.)))) ) ) ) (setq pr "RG") (cond ((and (setq s (ssget "_a" (list '(0 . "lwpolyline") '(90 . 4) (cons 410 (getvar 'ctab)))))) (setq l '("ID,LENGTH,WIDTH")) (setq n 0) (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (cond ((setq d (_r (mapcar 'cdr (vl-remove-if '(lambda (p) (/= 10 (car p))) (entget x))))) (entmakex (list '(0 . "TEXT") '(100 . "AcDbEntity") '(8 . "ID_Text") '(100 . "AcDbText") (cons 10 (last d)) (cons 40 (/ (cadr d) 2.)) (cons 1 (setq e (strcat pr (itoa (setq n (1+ n)))))) '(50 . 0.0) '(41 . 1.0) '(51 . 0.0) '(7 . "Standard") '(71 . 0) '(72 . 1) (cons 11 (last d)) '(210 0.0 0.0 1.0) '(100 . "AcDbText") '(73 . 2) ) ) (setq l (cons (strcat e "," (vl-princ-to-string (car d)) "," (vl-princ-to-string (cadr d))) l) ) ;; Writes CSV text file to same directory as drawing ) ) ) (_wf (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv") (reverse l)) ) ) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
tefached Posted April 30, 2020 Share Posted April 30, 2020 i need the same solution but is there a way to do the same but the ID is already on the drawing? Quote Link to comment Share on other sites More sharing options...
