symoin
LISP TO SELECT MULTIPLE LINES AND LABEL RATIO OF VERTICAL TO HORIZONTAL
symoin
Hi,
I have a lisp by Ranjith Singh, downloaded from autodesk forum and modified to show the ratio of vertical to horizontal. All I need is to select multiple lines and get the answer.
Thanks in advance
ratio.lsp
Share this post
Link to post
gS7
Try This
Codes Updated
(defun c:sr  (/ answer ss snm sp ep )
 (defun answer (pt1 pt2);ranjith sing
 (entmakex
  (list '(0 . "TEXT")
        '(100 . "AcDbText")
        (cons 10 (trans (mapcar '+ (mapcar '/ (mapcar '+ pt1 pt2) '(2 2))) 1 0))
        (cons 11 (trans (mapcar '+ (mapcar '/ (mapcar '+ pt1 pt2) '(2 2))) 1 0))
        (cons 1 (strcat "1:"(rtos (abs((lambda (x) (/ (car x) (abs (cadr x)))) (mapcar '- pt1 pt2))) 2 2) ))
	'(71 . 0)
	'(72 . 1)
	(cons 40 1)
        (cons 50 0))))
  (if (setq ss (ssget '((0 . "LINE"))))
	(setq snm (ssname ss (setq i (1- i))))
	(setq sp (vlax-curve-getstartpoint snm))
	(setq ep (vlax-curve-getendpoint snm))
	(answer sp ep))
Edited by gS7
Share this post
Link to post
symoin
Thanks GS7,
Yes This is what I was looking for;
I need a small modification, can the mtext chaged to text and the rotation to 0degree.
Share this post
Link to post
gS7
1 hour ago, symoin said:
Thanks GS7,
above codes updated
Share this post
Link to post
symoin
sorry my bad; it is not the requirement at all
Edited by symoin
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
