sage12
Export to PDF file
sage12
Whenever I try to export drawings from layout form to PDF, the preview always looks perfect, then has one edge cut-off after saved. I have tried several different aproaches to solve this problem, made sure the scale was 1:1, used extents,layout, center the plot. Nothing seems to work. Any help would be appreciated. I am using AUTOCAD 2014.
Thanks,Tom
Share this post
Link to post
maratovich
Give us pictures of what you get.
Share this post
Link to post
SLW210
Try plotting to PDF with DWG to PDF.pc3, I have never liked the Export to PDF.
Share this post
Link to post
BIGAL
I never like export as well, if you have a title block you may be better using a lower left upper right window, your extent option may be finding some thing you can not see. We have liitle corner markers on the title block and pick them works every time.
Are you using layouts and a title block ? Then it can be automated.
Share this post
Link to post
