jan_ek Posted January 17, 2019 Share Posted January 17, 2019 I have a 3d block. I would like to export coordinate to external file and insert the same block another drawing. However, I encountered a problem. I export dxf code 10, 41, 42.43, 50, 210 but that is no enough. If someone insert the block and use another cordinate system expoprt data is bad. What data i must export ? Quote Link to comment Share on other sites More sharing options...
Dani_Nadir Posted January 23, 2019 Share Posted January 23, 2019 On 1/17/2019 at 10:16 PM, jan_ek said: I have a 3d block. I would like to export coordinate to external file and insert the same block another drawing. However, I encountered a problem. I export dxf code 10, 41, 42.43, 50, 210 but that is no enough. If someone insert the block and use another cordinate system expoprt data is bad. What data i must export ? Hello jan_ek, Did you find a solution? I am interested in this. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted January 23, 2019 Share Posted January 23, 2019 Could it be as easy as setting UCS to world before running you code? Quote Link to comment Share on other sites More sharing options...
