nil28
insert 2 attributed blocks in one command one by one
nil28
I am using below program, but I want to update this program for the below
- in same command (CONDT), once I place the symbol "CONDUIT_", again it will ask me place the another block for which I will give the insertion point. e.g. attached CONDUIT_LEFT block I will get first then it will ask me to provide the insertion point & ask me give the two more attributes. Then "CONDUIT_DTLS" block will come. "TXT" attribute will same for both "CONDUIT_LEFT" & "CONDUIT_DTLS" block.
(defun c:CONDT (/ T_Rotation T_Point)
(setq Adia (getvar 'ATTDIA))
(setq Areq (getvar 'ATTREQ))
(setq Pf (getvar 'PICKFIRST))
(setvar 'PICKFIRST 1)
(setvar 'ATTDIA 0);;Required to feed Attribute values without a dialog box
(setvar 'ATTREQ 1);;Required for Turns on prompts or a dialog box for attribute values
(setvar 'CMDECHO 0)
(setq txt (getstring "\nYour text content for the Attribute: "))
   (while (setq T_Point (getpoint "Enter the point of insertion"))
    (initget 1 "Right Left Up Down")
    (setq T_Rotation (getkword "\nSelect Rotation [Right/Left]: "))
    (vl-catch-all-apply 'vl-cmdf
              (list "_.insert" (strcat "CONDUIT_" T_Rotation) T_Point 1 1 0 txt)
    (sssetfirst nil (ssget "L"))
    (C:BURST)
(setvar 'PICKFIRST Pf)
(setvar 'ATTDIA Adia)
(setvar 'ATTREQ Areq)
(setvar 'CMDECHO 1)
Thanks for the help!
CONDUIT_DTLS.dwg
CONDUIT_LEFT.dwg
Share this post
Link to post
BIGAL
It may be easiset to make a new defun for the other insert, then just run the two defuns one after the other. You also turn off the attribute input and turn it back on 0 & 1 ?
(defun condt2 ( / )
(c:condt)
(c:condtls)
Edited by BIGAL
Share this post
Link to post
nil28
I am trying to make program for "condtls" command, I want "CONDUIT_DTLS" block to be used by using this program which has 3 attributes. This command is like after giving command it will ask user to enter the point to place the block then it will ask to enter Text for attribute "DTLS1" & "DTLS2". For "Txt" attribute value should be same as which we have already provided in first "condt" program. I was trying to make below program for this but I am very bad in it so it is not working. Please help.
(defun c:condtls (/ T_Point Txt DTLS1 DTLS2)
(vl-load-com)
(setvar 'ATTREQ 0)
(setvar 'CMDECHO 0)
(if (= (setq DTLS1 (getstring T "\nYour text content for the DTLS1 Attribute: ")) "") (setq DTLS1" ")
         (setq DTLS2 (getstring T "\nYour text content for the DTLS2 Attribute: ")) "") (setq DTLS2" "))
              (list "_.insert" "CONDUIT_DTLS" T_Point 1 1 0)
    (setq obj (vlax-ename->vla-object (entlast)))
    (foreach att (vlax-invoke Obj 'GetAttributes)
       (if (= (vla-get-Tagstring att) "DTLS1") (vla-put-textstring att DTLS1))
       (if (= (vla-get-Tagstring att) "DTLS2") (vla-put-textstring att DTLS2))
       (if (= (vla-get-Tagstring att) "TXT") (vla-put-textstring att Txt))
(setvar 'CMDECHO 1)
(c:burst)
CONDUIT_DTLS.dwg
Share this post
Link to post
nil28
Hello all, Please help someone. Thanks in advance!
Share this post
Link to post
BIGAL
A couple of things you have localised txt so it will reset put it as variable to be passed (defun c:condtls (txt / T_Point DTLS1 DTLS2) BUT you must check that TXT exists before calling  so c:condtls rename it
(defun condtls2 (txt / T_Point DTLS1 DTLS2)
existing code
(defun c:condtls (/ )
(if (= txt nil)(getstring "enter txt string"))
(condtls2 txt)
Share this post
Link to post
