jim78b Posted January 31, 2019 Share Posted January 31, 2019 I don t know sonetimes i must reinstall autocad mech 2013 because when i try to export custom settings it give me error :error generate xml document .what can i do ? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 31, 2019 Share Posted January 31, 2019 Have you tried saving an ARG file its under "Config". You can select an ARG to load. Quote Link to comment Share on other sites More sharing options...
jim78b Posted February 1, 2019 Author Share Posted February 1, 2019 6 hours ago, BIGAL said: Have you tried saving an ARG file its under "Config". You can select an ARG to load. Yes save for the future when the problem Will happen Again. But i ask to you it i Only load the profile file .arg. i Will have app my toolbars customizations settings toolbar palette etc etc Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 2, 2019 Share Posted February 2, 2019 You need to adjust the start properties on the desktop Icon to load your profile its /p myprofile Quote Link to comment Share on other sites More sharing options...
jim78b Posted February 3, 2019 Author Share Posted February 3, 2019 Ok understand bug i ask you if it Will save all my customizations (toolbars, shortkeys etc) .i can e ven load profile in AutoCAD?! I read that Only arg file is not enough. Quote Link to comment Share on other sites More sharing options...
