Export custom settings xml error
jim78b
I don t know sonetimes i must reinstall autocad mech 2013 because when i try to export custom settings it give me error :error generate xml document .what can i do ?
6 hours ago, BIGAL said:
Have you tried saving an ARG file its under "Config". You can select an ARG to load.
Yes save for the future when the problem Will happen Again. But i ask to you it i Only load the profile file .arg.  i Will have app my toolbars customizations settings toolbar palette etc etc
Ok understand bug i ask you if it Will save all  my customizations (toolbars, shortkeys etc) .i can e ven load profile in AutoCAD?!
I read that Only arg file is not enough.
