DavidGraham Posted February 7, 2019 Share Posted February 7, 2019 I'm creating a DXF file containing 3D circles - see below. In the fist case the circle is just 2D, in the second case with the addition of codes 210, 220 & 230 (extrusion direction) the circle is 3D. Both circles are centred on the same point but the codes 10, 20 & 30 (centre point) are different. How do I work out what codes 10, 20, 30, 210, 220, 230 should be when I know the centre coordinates and the extrusion direction. 0 CIRCLE 8 L_BFC 10 -6.9288 20 -5.6034 30 3.2438 40 0.1331 0 CIRCLE 8 0 10 7.4879 20 5.3712 30 -2.2386 40 0.1327 210 -0.0891 220 0.8292 230 0.5519 In the second example I changed just the 210, 220 & 230 values - I expected the circle to stay in the same location and just the orientation - but the circle moves to a new location (with . 0 SECTION 2 ENTITIES 0 LINE 8 L_VCL 10 -6.9288 20 -5.6034 30 3.2438 11 -6.6511 21 -4.7621 31 3.7076 0 CIRCLE 8 L_BFC 10 -6.9288 20 -5.6034 30 3.2438 40 0.1331 0 CIRCLE 8 0 10 7.4879 20 5.3712 30 -2.2386 40 0.1327 210 0.2777 220 0.8413 230 0.4638 0 ENDSEC 0 EOF How do I work out what codes 10, 20, 30, 210, 220, 230 should be, when I know the centre coordinates and the extrusion direction? Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted February 7, 2019 Share Posted February 7, 2019 (setq PointInOCS (trans PointInWCS 0 normal)) Quote Link to comment Share on other sites More sharing options...
