GLORY Posted February 12, 2019 Share Posted February 12, 2019 Hello, I just want to ask regarding the program I want to make cause I am having a problem on how to multiply the two values ( a real number and value from an input box): Part of my DCL; : edit_box { key = "sc"; label = "ENTER SCALE :"; alignment = centered; width = 10; fixed_width = true; is_enabled = false;} Part in my LISP; (set_tile "sc" "500") (mode_tile "sc" 2) (action_tile "en" "(progn (setq en $value)(mode_tile \"sc\" 0))") (action_tile "accept" "(setq scale (get_tile \"sc\") (done_dialog 1) )" ) (defun Styles() (setq size (* 0.00225 scale)) ….) but after running the program just exit. Hope someone can have time to help with this. Thank you! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 12, 2019 Share Posted February 12, 2019 (setq size (* 0.00225 (distof scale))) Quote Link to comment Share on other sites More sharing options...
GLORY Posted February 12, 2019 Author Share Posted February 12, 2019 @ Tharwat Thank you so much. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted February 12, 2019 Share Posted February 12, 2019 57 minutes ago, GLORY said: @ Tharwat Thank you so much. You're welcome. Quote Link to comment Share on other sites More sharing options...
