AutoCad 12 & 13 DOS Issue
acad_2k
During the recent cold snap, I decided to go thru my collection of computers, parts and software.  I still have my first two PC's, a Compaq 486 and a HP Pentium 1. I also have my first two AutoCad purchases, R12 DOS and R13 which I used in DOS mode but later in Windows 95. I formatted both hard drives and did a clean install of DOS on both machines and then installed R12 in the 486 and R13 in the 166.
The problem I am having is that when I start Autocad, I cannot access the drawing editor. I get a AutoCad command prompt in the DOS screen. If I type 'open', it asks for a drawing name, so I loaded some R12 sample drawings but Acad cannot access them. Both computers have the exact same problem.
I seem to recall having the same problem when I first purchased them back way back and Autodesk walked me thru it.
Any suggestions would be helpful.
Thanks in advance.
I realize that this particular forum is off the beaten path, so if anyone has a suggestion of where to post my question regarding R12 & R13 DOS,  I would greatly appreciate it.
I seem to remember that the search paths had to be loaded every time Autocad was used, with a batch file.
I presume that you have done this and have tried typing the full path to where the drawing is.
These are cad environment settings I use
SET ACAD=\ACAD\12;\ACAD;\ACAD\LIB;\ACAD\FONTS;\ACAD\UT;\ACAD\LIB\BORDERS;\ACAD\FONTS\BIG;\ACAD\KCL;
SET ACADCFG=\ACAD\12
SET ACADDRV=\ACAD\12
In the batch file that starts ACAD for R12 installed in c:\acad\12\
Edited by David Bethel
  • 10 months later...
well, I have to say that I am completely lost. Where exactly do I add these lines?
I gave up on R12 last winter and am now having the exact same problem with R13. I installed it in a Windows 98 machine and can access AutoCAD in Windows, but in DOS Mode, when I open Autocad, I get a Autocad "command" prompt in the DOS screen.
From the C:\ prompt, I can find my way to the autocad directory
I read some of the Autocad R13  "Installation For DOS Guide" and made an attempt to edit the Autocadr13.bat file (I really don't know what the hell I am doing), anyway, here is a screen shot...
Seems like your AutoCAD folder is named "ACADR13" so make sure you are reflecting that correctly in your batch file. In your case it would be:
SET ACAD=C:\ACADR13\SUPPORT;C:\ACADR13\FONTS;C:\ACADR13\ADS
SET ACADCFG=C:\ACADR13
SET ACADDRV=C:\ACADR13\DRV
C:\ACADR13\ACAD %1 %2
Attached is my ACADR13.BAT for reference.
On 12/20/2019 at 12:11 AM, acad_2k said:
..........From the C:\ prompt, I can find my way to the autocad directory
When you are there, what happens if you just type "ACAD"
I know R12DOS required this.
I think R13DOS did as well.
In  'c:/windows/system/' : verify this file exists
PHARLAP.386
In 'c:/windows/' : Edit/Add/Verify  'c:\windows\system.ini'
[386Enh]
device=pharlap.386
This is one of the main problems for ACAD when trying to setup virtual machine for DOS.
Win98SE should work fine.
-David
8 hours ago, acad_2k said:
I updated the file, but no luck. Whenever I start autocad, I get a "command" prompt (COMMAND:) but no drawing editor.
This sounds like a configuration problem.
At the Command: prompt, please type “config” and press enter. You will be presented with a screen that shows your current configuration. For reference I am attaching the screen I see when typing this command. Please take a photo of what you see and post it here.
Thanks guys for the responses. I'm sure I've mucked up the OS settings so I just formatted the hard drive and am doing a fresh install of DOS 6.21 on my Compaq 486 machine.  Will upload some screen shots after AutoCAD R12 is installed.
When I first start AutoCAD from the DOS prompt, C:\, the start-up page reads:
"BASE.dcl" : Can't open file
Error loading dialog control file
Press RETURN to continue
RETURN
prototype drawing acad is not on file. Using defaults
RETURN
login was successful
"TXT.shx"
can't open file
RETURN
enter another font file name for style STANDARD (or RETURN for none)
RETURN
"ACAD.mnu"
can't open file
RETURN
enter another menu file name (or RETURN for none)
RETURN
Command:
So now I will try "config" at the command prompt.
video, digitizer, plotter configs that I chose during install (none) are what is displayed
RETURN
Configuration menu:
0: exit to drawing editor
1: show current config
2: allow detailed config
3: config video
4: config digitizer
5: config plotter
6: config system console
7: config operating parameters
Enter selection (0):
I'll wait at this stage for instructions
All of the “Can’t open file” messages indicate that you need to use a batch file like the one we were initially working on. Those SET strings are used to tell AutoCAD where to find those files.
