Make boundary
Jord_91
Hey guy's I've got this lisp that is working pretty well with an end user but when I try to add it to a script it saids that it's an Unknown command... is there something in it that is wrong?
(defun lib:Zoom2Lst( vlist / bl tr Lst OS)
(setq Lst (lib:pt_extents vlist)
bl (car Lst) tr (cadr Lst))
(if (not (and (lib:IsPtInView bl) (lib:IsPtInView tr)))
(progn  (setq OS (getvar "OSMODE"))(setvar "OSMODE" 0)
(command "_.Zoom" "_Window" (trans bl 0 1)(trans tr 0 1)
 "_.Zoom" "0.95x")
(setvar "OSMODE" OS)
 T) NIL))
;External contour of objects
(defun C:MakeBoundary ( / *error* blk obj MinPt MaxPt hiden pt pl unnamed_block isRus
      tmp_blk adoc blks lays lay oname sel csp loc sc ec ret DS osm iNSpT)
(defun *error* (msg)(princ msg)(mapcar '(lambda (x) (vla-put-Visible x :vlax-true)) hiden)
(vla-endundomark adoc)(if (and tmp_blk (not (vlax-erased-p tmp_blk))(vlax-write-enabled-p tmp_blk) )
(vla-Erase tmp_blk))(if osm (setvar "OSMODE" osm))(foreach x loc (vla-put-lock x :vlax-true)))
(vl-load-com)(setvar "CMDECHO" 0)(setq osm (getvar "OSMODE"))
(if (zerop (getvar "WORLDUCS"))(progn(vl-cmdf "_.UCS" "")(vl-cmdf "_.Plan" "")))
(setq isRus (= (getvar "SysCodePage") "ANSI_1251"))
(setq adoc (vla-get-ActiveDocument (vlax-get-acad-object))
       blks (vla-get-blocks adoc) lays (vla-get-layers adoc))
 (vla-startundomark adoc)(if isRus (princ "\n???????? ??????? ??? ?????????? ???????")(princ "\nSelect objects for making a contour"))
 (vlax-for lay lays
     (if (= (vla-get-lock lay) :vlax-true)
         (progn (vla-put-lock lay :vlax-false) (setq loc (cons lay loc))))
(if (setq sel (ssget))(progn
   (setq sel (ssnamex sel))
;;;    (setq iNSpT(apply 'mapcar (cons 'min
;;;     (mapcar 'cadr (apply 'append (mapcar '(lambda(x)(vl-remove-if-not 'listp x)) sel))))))
   (setq iNSpT '(0 0 0))
   (setq sel (mapcar 'vlax-ename->vla-object(vl-remove-if 'listp (mapcar 'cadr sel))))
   (setq csp (vla-objectidtoobject adoc (vla-get-ownerid (car sel))))
  ; (setq unnamed_block (vla-add (vla-get-blocks adoc)(vlax-3d-point '(0. 0. 0.)) "*U"))
   (setq unnamed_block (vla-add (vla-get-blocks adoc)(vlax-3d-point inspt) "*U"))
   (foreach x sel
     (setq oname (strcase (vla-get-objectname x)))
     (cond ((member oname '("ACDBVIEWPORT" "ACDBATTRIBUTEDEFINITION" "ACDBMTEXT" "ACDBTEXT")) nil)
    ((= oname "ACDBBLOCKREFERENCE")
     (vla-InsertBlock unnamed_block
       (vla-get-insertionpoint x)(vla-get-name x)
       (vla-get-xscalefactor x)(vla-get-yscalefactor x)
       (vla-get-zscalefactor x)(vla-get-rotation x))
     (setq blk (cons x blk)))
    (t (setq obj (cons x obj)))));_foreach
       (setq lay  (vla-item lays (getvar "CLAYER")))
       (if (= (vla-get-lock lay) :vlax-true)(progn (vla-put-lock lay :vlax-false) (setq loc (cons lay loc))))
    (if obj (progn (vla-copyobjects (vla-get-activedocument (vlax-get-acad-object))
             (vlax-make-variant (vlax-safearray-fill
                 (vlax-make-safearray vlax-vbobject (cons 0 (1- (length obj))))
                 obj)) unnamed_block)))
   (setq obj (append obj blk))
   (if obj (progn
         ;(setq tmp_blk (vla-insertblock csp (vlax-3d-point '(0. 0. 0.))(vla-get-name unnamed_block) 1.0 1.0 1.0 0.0))
             (setq tmp_blk (vla-insertblock csp (vlax-3d-point inspt)(vla-get-name unnamed_block) 1.0 1.0 1.0 0.0))
         (vla-GetBoundingBox tmp_blk 'MinPt 'MaxPt)  ;_??????? ?????
              (setq MinPt (vlax-safearray->list MinPt) MaxPt (vlax-safearray->list MaxPt)
      DS (max (distance MinPt (list (car MinPt)(cadr MaxPt)))
       (distance MinPt (list (car MaxPt)(cadr MinPt))))
             DS (* 0.2 DS) ;1/5
      DS (max DS 10) MinPt (mapcar '- MinPt (list DS DS))
                    MaxPt (mapcar '+ MaxPt (list DS DS)))
(lib:Zoom2Lst (list MinPt MaxPt))(setq sset (ssget "_C" MinPt MaxPt))
(if sset (progn (setvar "OSMODE" 0)
     (setq hiden (mapcar 'vlax-ename->vla-object(vl-remove-if 'listp (mapcar 'cadr (ssnamex sset))))
    hiden (vl-remove tmp_blk hiden))
     (mapcar '(lambda(x)(vla-put-Visible x :vlax-false)) hiden)
     (setq pt (mapcar '+ MinPt (list (* 0.5 DS)(* 0.5 DS))))
     (vl-cmdf "_.RECTANG" (trans MinPt 0 1)(trans MaxPt 0 1))
     (setq pl (vlax-ename->vla-object(entlast)))
     (setq sc (1-(vla-get-count csp)))
     (if (VL-CATCH-ALL-ERROR-P (VL-CATCH-ALL-APPLY '(lambda ()
        (vl-cmdf "_-BOUNDARY" (trans pt 0 1) "")
             (while (> (getvar "CMDACTIVE") 0)(command "")))))
     (if isRus (princ "\n?? ??????? ????????? ??????")(princ "\nIt was not possible to construct a contour")))
     (setq ec (vla-get-count csp))
       (while (< sc ec)(setq ret (append ret (list (vla-item csp sc))) sc(1+ sc)))
     (setq ret (vl-remove pl ret))
     (mapcar '(lambda (x)(vla-Erase x)(vlax-release-object x))(list pl tmp_blk))(setq pl nil tmp_blk nil)
     (setq ret (mapcar '(lambda ( x / mipt)(vla-GetBoundingBox x 'MiPt nil)  ;_??????? ?????
                (setq MiPt (vlax-safearray->list MiPt))(list MiPt x)) ret))
     (setq ret (vl-sort ret '(lambda (e1 e2)(< (distance MinPt (car e1))(distance MinPt (car e2))))))
     (setq pl (nth 1 ret) ret (vl-remove pl ret)) (mapcar 'vla-erase (mapcar 'cadr ret))
     (mapcar '(lambda(x)(vla-put-Visible x :vlax-true)) hiden)
     (if pl (progn (initget  "Yes No")
     (if (= (getkword (if isRus "\n??????? ???????? [Yes/No] <No> : " "\nDelete objects? [Yes/No] <No> : ")) "Yes")
        (mapcar '(lambda (x) (if (vlax-write-enabled-p x)(vla-Erase x))) obj)))
(if isRus (princ "\n?? ??????? ????????? ??????")(princ "\nIt was not possible to construct a contour")))))))
    (VL-CATCH-ALL-APPLY '(lambda ()(mapcar 'vlax-release-object
   (list unnamed_block tmp_blk csp blks lays))))));_if not
 (foreach x loc (vla-put-lock x :vlax-true))(setvar "OSMODE" osm)
 (vla-endundomark adoc)(vlax-release-object adoc)(princ))
Could you help me please!! :)
Edited by Jord_91
23 minutes ago, rlx said:
Does your script include as the first line : (load "makeboundary.lsp") and where/when is this function loaded : (lib:pt_extents vlist)?
Hi, you have some great questions! In fact, I’m using the script writer of Lee Mac sort I can use normal commande of AutoCAD and usually call Lisp without probleme  . As I’m actually trying to learn lisp I’m a certified noob at what’s missing or els.
the same probably goes for the function
lib:IsPtInView
But its a common problem , forgetting to include your little 'helper' functions. Just include their defun's in your main defun
(defun c:MakeBoundary ( / _lib1 _lib2 var1 var2 etc.)
  (defun _lib1 ()(bladiebla))
  (defun _lib2 ()(blehdiebleh))
  (setq var1 1 var2 2)
  ; etc
lib:IsPtInView
  ; etc
In Fact, Here's the full Code
;; !                  lib:IsPtInView
;; ! Auguments: 'pt'  - ????? ??? ??????? ? ???!!!
;; ! Return   : T ??? nil ???? 'pt' ? ??????? ?????? ??? ???
(defun lib:IsPtInView (pt / VCTR Y_Len SSZ X_Pix Y_Pix X_Len Lc Uc)
(setq pt (trans pt 0 1))
(setq VCTR (getvar "VIEWCTR") Y_Len (getvar "VIEWSIZE")
  SSZ (getvar "SCREENSIZE")
  X_Pix (car SSZ) Y_Pix (cadr SSZ)
  X_Len (* (/ X_Pix Y_Pix) Y_Len)
  Lc (polar VCTR (dtr 180.0) (* 0.5 X_Len))
  Uc (polar Lc 0.0 X_Len)
  Lc (polar Lc (dtr 270.0) (* 0.5 Y_Len))
  Uc (polar Uc (dtr 90.0) (* 0.5 Y_Len)))
(if (and (> (car pt) (car Lc))(< (car pt) (car Uc))
 (> (cadr pt) (cadr Lc))(< (cadr pt) (cadr Uc)))
T nil))
(defun DTR (a)(* pi (/ a 180.0)))
;; !           lib:pt_extents
;; ! Function : ?????????? ??????? MIN, MAX X,Y,Z ?????? ?????
;; ! Argument : 'vlist' - ?????? ?????
;; ! Returns  : ?????? ????? (??????? ?????????)
(defun  lib:pt_extents (vlist / tmp)
(setq tmp (mapcar '(lambda (x) (vl-remove-if 'null x))
(mapcar '(lambda (what) (mapcar '(lambda (x) (nth what x)) vlist))
'(0 1 2))));_setq
 (list (mapcar '(lambda(x)(apply 'min x)) tmp)(mapcar '(lambda(x)(apply 'max x)) tmp)));_defun
;http://www.theswamp.org/index.php?topic=15123.0
;;;(defun GetBoundingBox-3d (pt_lst)
;;;  (list (apply 'mapcar (cons 'min pt_lst))
;;; (apply 'mapcar (cons 'max pt_lst))
;; !                             lib:Zoom2Lst
;; ! Function : Zoom ?????? ?????? ?????
;; ! Arguments: 'vlist' - ?????? ????? ? ???!!!!
;; ! Returns  : t - ???? ???????????? nil - ???
 "_.Zoom" "0.95x")
 T) NIL))
(defun C:ECO ( / *error* blk obj MinPt MaxPt hiden pt pl unnamed_block isRus
 (vlax-for lay lays
   (foreach x sel
   (if obj (progn
             DS (* 0.2 DS) ;1/5
I thought that I could take only what i needed from it as it works just fine with an end user only this part but I might be missing something that makes it able to lunch in a Script.
I don't think this will ever work in a script : (ssget) in this form requires a user input so either you must include this input in your script or use (ssget "w" '( 0 0) '(10 10)) or with a filter with the "X" option. But I suppose you could do something like :
(load "makeboundary")  ; load appie
(c:makeboundary)       ; run appie
all                    ; select all
                       ; end selecting with empty line
no                     ; delete original object?
.qsave                 ; save your drawing
pfff light's out for me for a moment... the flu... bummer...
p.s.
Lee has some boundary lisps on his site like : http://www.lee-mac.com/outlineobjects.html
Edited by rlx
all                    ; select all
p.s.
I try it but never manage to make it work as I wish it would... Finally with my collegs we decided to pass our way on this and got our final drawing looking as we would like 🤗.
Now the only thing that is missing to make everything working fine is to find a way to add point at the corner of a surface / region... As it's not considered as a Polyline pwlin or a normal line it's not working. 😒 I'm kind of tired of working on this... I made Like tooooooooooooooo many post for different things for this one -_-
Edited by Jord_91
sometimes all the effort to create a lisp routine can be disproportionate to just some good old manual labour. And sometimes leaving a problem alone for a while can help to start with a fresh look. My work has more to do with electric signals so no complex drawings or drawing objects. Maybe post a drawing example with what you have and what you want it to become can show better your problem , excuse me , your challenge , so other (and brighter) people can post tips on how to tackle your problem. Odds are you're not the only / the first one to do what you want to do.
ever checked this link? : http://forums.augi.com/showthread.php?76768-OBTAINING-BOUNDARY-BOX-POINTS-OF-AN-OBJECT-IN-UCS
Edited by rlx
