Aftertouch Posted February 28, 2019 Share Posted February 28, 2019 Hello all, I have a block in a DWG, created with WBLOCK, wich is annotative. When i want to insert the block with vla-insertblock, the block becomes not annotative. When i insert the block with the vanilla (command "insert") method. it works fine. Does the vla-method requires something extra to work??? Quote Link to comment Share on other sites More sharing options...
