jim78b Posted March 8, 2019 Share Posted March 8, 2019 hello i see that when i double click on a dwg file to open for first time autocad. autocad create the log dwg file in the same dir that i opened the drawing. if i start before autocad and then click on the dwg file the log file path is correct, why this? Quote Link to comment Share on other sites More sharing options...
ammobake Posted May 16, 2019 Share Posted May 16, 2019 When you open CAD before opening a file, it is running locally only (on your computer) and writing the log file to the default location in your settings (I believe default is a temp folder). If you open a file on a server or mapped drive the log file is saved alongside the DWG for reference and easy access later on (in the same directory). This is easy to fix. The "automatic save file location" can be changed to whatever drive or path you choose in settings, files tab. Everytime the program autosaves it will save to that directory instead of all over the place. It is a good idea to set up a dedicated folder just for autosaves - on a separate drive, if possible. -ChriS Quote Link to comment Share on other sites More sharing options...
