make specific layer text into bold
amb2301
Hi Friends,
     please someone help me to do the following task in Lisp,
I need lisp to select the layer called "Anno1" & make the text to bold on that layer.
You don't need lisp to do this. Look into the FILTER command or QSELECT. Make your selection and modify within properties palette.
Hi Ronjonp,
        Thanks for your reply,
Actually, i have lisp, which does some work in a drawing & in addition to that i need to do the above task in that same lisp,
so could you please provide me lisp.
51 minutes ago, amb2301 said:
Hi Ronjonp,
If you have existing code then you should post what you have and maybe someone can modify it to do what you need.
Edited by ronjonp
